Myford ML7 Motor
Myford ML7 Motor
Home › Forums › Manual machine tools › Myford ML7 Motor
  • #864922
    ian Holdsworth
      @ianholdsworth27760
      Does anyone know wher I can purchase a good used motor for my lathe. I nee a single phase 240v motor either a rewind or a used one that is in good condition
      #864925
      Nigel Graham 2
        @nigelgraham2
        Mine is spare since I converted the lathe to 3ph. I kept it as a spare lest the conversion broke down (as it once did when a swarf snake found its way into the motor) but I will consider selling it.
        #864982
        noel shelley
          @noelshelley55608
          Hi Ian, If you understand motors then the following will be little help. The original motor was a resilient mount 1/2 Hp motor at 1420 rpm and for most 240V. Ml7R and S7 used a 3/4Hp motor and there is no reason not to use this slightly higher power. Modern motors express the power often in Kw so 0.37 Kw (1/2Hp) or 0.55Kw (.75Hp). I used a solid mount .75Hp on an old S7 and it worked fine, and it was to hand.
          If cost is not important then you could upgrade to a VFD conversion of which there are several ways from buying a suitable motor and VFD unit to a pre wired kit you just bolt on.
          The motor shaft is 5/8″ from memory.         Good luck.  Noel/
          #864991
            Where are you, Ian ?
            [no details in your forum profile]
            If a trip to North Wales is feasible … please send me a P.M.
