Interpreting hex nut description
Home Forums General Questions Interpreting hex nut description
  • #548321
    Bill Phinn
      @billphinn90025
      I've just bought two kinds of 1/2" BSW hex nuts from Zoro:
      https://www.zoro.co.uk/shop/fasteners/hexagon-nuts/1-2-bsw-hex-machine-screw-nut-freecut/p/ZT1095040X
      https://www.zoro.co.uk/shop/fasteners/hexagon-nuts/1-2-bsw-steel-hex-full-nut-bzp/p/ZT1094836X
      Can anyone tell me what the term "freecut" means in the case of the first kind?
      Thanks!
      #28204
      Bill Phinn
        @billphinn90025
        #548323
        Anonymous
          Probably nothing of any engineering significance.
          #548325
          old mart
            @oldmart
            I can only think that somebody has assigned that code to a particular type of nut and that "freecut" has no particular meaning. Look at the long strings of code at the top of each page when you are online, it is only an index.
            #548326
            pgk pgk
              @pgkpgk17461
              Best guess that it means "as they come" as opposed to bzp or passivated …
              pgk
              #548327
                One is grade 6, the other grade 8. one is BZP the other uncoated
                #548328
                Bill Phinn
                  @billphinn90025
                  Thank you for the replies.
                  I notice that the nuts described as freecut are assigned to both grade P and grade 6 simultaneously. Presumably these are alternative descriptions for what is essentially the same grade of steel.
                  I've just found the following (http://www.fasnetdirect.com/refguide/Metnutst1cl810.pdf), which may explain the use of the term freecut in this case:
                  "Class 6 nuts shall be made of a steel which conforms to the following chemical composition– Carbon: 0.50% maximum; Phosphorus: 0.060% maximum; Sulfur: 0.150% maximum.
                  Class 6 nuts may also be made from free-cutting steel which conforms to the following chemical composition–Carbon: 0.50% maximum; Sulfur: 0.34% minimum; Phosphorus: 0.11% minimum; Lead: 0.35"
                  #548329
                  Bill Phinn
                    @billphinn90025
                    Posted by JasonB on 04/06/2021 18:53:39:
                    Thanks Jason. I knew that already. One other difference is the freecut nuts have a bigger af measurement than the grade 8 bzp ones.
                    Edited By Bill Phinn on 04/06/2021 19:01:22
                    #548332
                      'Qualcast' make lawnmowers and hedge-trimmers. Maybe 'Freecut' refers to that. Buy only genuine Qualcast nuts and bolts! Available at all good ironmongers…
                      PS.
                      Tempting to use my Moderator superpowers to delete my own foolishness.   Qualfast is not the same as Qualcast.  Second time today I've misread something and put my foot in it!
                      Edited By SillyOldDuffer on 04/06/2021 19:19:13
                      #548334
                      old mart
                        @oldmart
                        Posted by SillyOldDuffer on 04/06/2021 19:06:30:
                        PS.
                        If you were the worrying kind, you wouldnt have chosen that monika
                        #548335
                          https://www.ebay.co.uk/itm/283413042917
                          If I can get a look at BS1083 … I will let you know if it has anything that looks relevant
                          So far as I can see … the word ‘freecut’ does not appear in the Standard …
                          and incidentally, ‘Grade A’ is the lowest specification.
                          Edited By Michael Gilligan on 04/06/2021 19:49:43
                          #548338
                          Bill Phinn
                            @billphinn90025
                            I assumed you were just joshing, Dave, so no harm's been done.
                            Actually harm has been done, because I now can't excusably wheel out the groan-inducing anecdote about my father's knackered old Qualcast lawnmower that had one particular nut that always kept falling off it; someone had put a hex on it, you see.
                            ETA: Thank you, Michael.
                            Edited By Bill Phinn on 04/06/2021 19:34:04
                            #548339
                            jimmy b
                              @jimmyb
                              Michael
                              BS1083
                              Jim
                              #548340
                                Posted by jimmy b on 04/06/2021 19:38:46:
                                Michael
                                BS1083
                                Jim
                                Tut Tut … I’m surprised they are getting away with publishing that dont know
                                https://shop.bsigroup.com/ProductDetail?pid=000000000000066806
                                Edited By Michael Gilligan on 04/06/2021 19:55:45
