A lifting injector is "the same as" a non-lifting one, with the exceptions:
– a lifting one needs to work as an "ejector" to lift the water up into the injector; (some full size ones lack this ability) – it means that the overflow needs to be quite large to reduce back-pressure;
– any injector needs to not heat the incoming water too much; in our small injectors, there's a large surface area to water volume as compared to the full-size; having water drip through it keeps it cool, so the steam from the steam cone has a better chance of condensing.
Duncan – on one coal-fired steam crane I used to supervise over here in Canada, one of the volunteers had trouble with the Hancock Inspirator, which should have been self-priming, and lots of steam went out the overflow, which was plumbed BACK into the water tank. Water was low in the boiler; I could not get the injector to lift; the water tank was very warm to the touch; got a fire hose to fill the water tank with cold water, and things were back to normal.
Anyway, just my tuppence on this beautiful day.
