Info required
Info required
Home › Forums › Workshop Tools and Tooling › Info required
  • #19567
    Bernard Reilly
      @bernardreilly64467
      Warco WM16 or 16 B power head lift
      #443363
      Bernard Reilly
        @bernardreilly64467
        A happy Christmas to all. Has any one fitted a power assisted mill head lift to any of these machines or something similar. A web search revealed images of head hand wheel relocated to bottom of column however no article write up.
        Thank you B Reilly Glasgow.
        #443432
        not done it yet
          @notdoneityet
          Do you mean a telescopic gas ram simply to reduce the effective weight of the head while manually winding, or do you mean something like a battery operated screwdriver to drive the moved hand wheel?
          #443435
          Enough!
            @enough
            (Double posting deleted)
            Edited By Bandersnatch on 27/12/2019 01:00:31
            #443436
            Enough!
              @enough
              Posted by Bandersnatch on 27/12/2019 00:59:26:
              Posted by Bernard Reilly on 26/12/2019 13:32:17:
              Don't know about a "power assisted mill head" …. I just use a socket (from a socket set) on a suitable adaptor in an electric drill/driver (with the clutch set so i don't overdrive).
              #443438
              Paul Lousick
                @paullousick59116
                Lots of articles on the internet, Youtube, etc about adding a power feed to the Z-axis screw. Mostly using a stepper motor for CNC conversion but no reason a standard gearmotor could not be used instead just to raise and lower the head.
                Paul.
                #443460
                David George 1
                  @davidgeorge1
                  Hi i did a convesion to my Chester mill 16V to move the handwheel and fit a motor. I changed the leadscrew to a ball screw moved the handweel to a 90 deg bevel gear and fitted a stepper motor after fitting a geared motor which was a failure as at low speed it was jerky and no power. It is perfect to fast traverse and fine cut boring or drilling is great. I have drawings if you want them fir inspiratuon and there are pictures on one of my albums on here.
                  David
                  #443615
                  Bernard Reilly
                    @bernardreilly64467
                    Hi thanks to all for informative reply's. In answer to not done it yes the object of the exercise is to purely to overcome the weight of the head on manual lift operation.. I have come across a short video on U Tube showing the installation of a gas strut on a rack operated head system. Would a gas strut work on a leadscrew & nut system. ? I just want to keep things a simple as possible as not into electronics.
                    Many thanks and a happy New Year to all B. Reilly Glasgow.
                    #443653
                    not done it yet
                      @notdoneityet
                      I just entered ‘gas’ in the forum search and a previous thread on gas struts appeared along with links to earlier threads.
                      My query to you was to try to determine what you were looking for.smiley Anything that reduces the effective weight will reduce the lifting effort. Racks with pinions just seem to be a more coarse (less refined?) alternative to a feed screw.
                      #443659
                      Enough!
                        @enough
                        FWIW Little Machine Shop sells air-springs and kits for mini-mills.
