ID required of air pump
Home › Forums › General Questions › ID required of air pump
  • #186506
    richard3267
      @richardrogalewski21509
      Hi. Can anyone please identify this contraption. It's an air pump of some kind. About 24Cm long. Dia. about 13Cm. Shft is splined. Feet are homebrew.
      Stamped on it is: "REF 378 1251 -gov't arrow symbol -SER AG10314.
      Inside a tiny circle are "P 16" Also a stamp " E 1".
      #23815
      richard3267
        air pump
        #186509
        richard3267
          Could it be a supercharger? Roots type? Maybe not a roots type, not oblong enough.
          Edited By Richard Rogalewski on 15/04/2015 17:16:53
          #186537
          frank brown
            @frankbrown22225
            Looking at all those bolts holding the pump together and the air inlet pipe, take air at 100 psi and raises it to 500 psi? I don't think there are enough bolt holes in the original mounting flange.
            Frank
            #186545
            richard3267
              Here is a close-up of the outlet. Wonder if that says anything.
              Screwed onto it is what looks to be a homemade gadget so you can hook up a hose.
              Edited By Richard Rogalewski on 15/04/2015 19:31:40
              #186546
              richard3267
                What I will do, is connect the pump to a motor and see what air pressure it outputs. May try my Hoover 1/6th HP at 950RPM and see what gives.
