HSS replacement tool tips.
Home › Forums › General Questions › HSS replacement tool tips.
  • #27559
    Alistair Robertson 1
      @alistairrobertson1
      #489711
        @alistairrobertson1
        I wonder if anyone can help me with a source for HSS TCMT 1603 replacement tips? I worked for a company about 20 years ago and they had various types of tips in High Speed Steel.
        The supplier was a common supplier of tips at the time but the name totally escapes me. Can anyone remember and if they are still available?
        #489724
        Robert Dodds
          @robertdodds43397
          Alistair,
          There are plenty of sources for TCMT 1603-04 but they are Tungsten Carbide not High Speed Steel. Are you sure about the HSS bit?
          Google throws up hobby supplies with a range of prices. See what you think.
          Bob D
          #489728
          Hillclimber
            @hillclimber
            Like these AR Warner tips? I use these, and think they're great. But have to order them from Little Machine Shop…
            https://littlemachineshop.com/products/product_category.php?category=-1550042347&Brand=A+R+Warner
            #489732
            Bill Pudney
              @billpudney37759
              I too use A.R.Warner HSS tips. Top stuff, easy to give a touch up to on a diamond plate. They are not cheap but they are excellent!!
              cheers
              Bill
              #489735
              colin vercoe
                @colinvercoe57719
                The tips you require are available from Plansee SM 80 grade sintered HSS various sizes and geometrys brilliant tips and can be re lapped. use speeds and feeds as for HSS these were available 20 years ago plansee way ahead of most of the tip manufactures at the time
                #489750
                Hillclimber
                  @hillclimber
                  Posted by colin vercoe on 09/08/2020 00:28:32:
                  Do you have an internet link for 'Plansee'? Tried googling but did not see anything helpful.
                  Cheers, Colin
                  #489775
                  colin vercoe
                    @colinvercoe57719
                    Try Plansee Tizit lots of info here
                    Cheers
                    #489783
                      @alistairrobertson1
                      Thanks for all the info and yes Plansee was the name I was looking for!
                      There was also an American supplier but that was many years ago!
                      Just got to find a supplier but at least I can now search for something.
                      Thanks to all!
                      #489802
                      Paul H 1
                        @paulh1
                        #489810
                        Circlip
                          @circlip
                          " Plansee SM 80 grade sintered HSS various sizes and geometrys brilliant tips and can be re lapped. use speeds and feeds as for HSS "
                          But HSS is HSS is HSS
                          Regards Ian.
                          #489834
                            Posted by Circlip on 09/08/2020 12:27:35:
                            Regards Ian.
                            … at least to a reasonable approximation angel
                            A History Of High Speed Steel
                            Versaboss
                              @versaboss
                              Another, not very well known manufacturer, is Alesa
                              Here, the HSS inserts, but beware: they are not cheap! It is possible to get them piecewise, though.
                              HSS tooling
                              Hans
