Hi, Richard,
We don’t have Beau-max in Arad, but we do have several large DIY warehouses of German origin (Obi, Praktiker). These are identical in layout and services to the German ones (I lived in Germany for 25 years), right down to the cutting equipment installed in the wood departments. Both stores will (sometimes) cut the wood to size for you (depends on which employee is on duty that day) – this is still a risky business – Romanian millimetres seem to be elastic compared to those on my ruler, so it is safer to specify the sizes as bigger than actually required. The clincher comes after they have cut it – you still have to pay for the whole sheet!. I found this out very shortly after I arrived here. Buying the whole sheet was not that expensive, but it was a b….r to get home, and I wasn’t going to leave two thirds of the sheet in the store! – it explains why nearly everyone I know around here has a circular saw
Buying planed ‘dry’ timber is even more difficult – you have to get an itemised receipt of what you bought – not a till receipt – they usually have to be written out in longhand by one specific employee (which can be a bit like the old joke of being sent for a long wait). Apparently this is to protect you and the shop in the event the police stop you on the way home – then you can ‘prove’ you bought the timber legitimately instead of stealing it. Green (highly suitable for warping) timber does not need this receipt – go figure!. Needless to say, they don’t sell much timber.
My experiences with UK postal charges have originated with the suppliers – I have had some really crazy quotes to send to Europe, compared with the same companies shipping within UK, so I get them to send it to my brother, who then trots down the local post office, and sends it simple parcel post – it has always so far worked out much cheaper – so my gripe is with the suppliers. When I have queried their prices, I have been told ‘It is for post and PACKING, sir – we have to make sure it is packed OK and isn’t damaged in transit’, so some packing can cost a fortune, it appears (…..but not when sent from Germany, it seems). Perhaps someone in business can justify this?
It is also possible to buy various solders here made by a German company called Rolot (I think they also sell in UK). They have many different types, for plumbing and other purposes, and there are several which are marketed under similar descriptions as you mention. The packages usually state the intended use, and give things like melting temperatures, but I have to say I have never had much luck with them – there does not seem to be anything with the characteristics of Easyflow. I did find one which appeared to melt at the same temperature as Easyflow, covered with a very pale yellow flux. I finally did get it to melt using an oxy/gas flame, but no way will it run into a joint – it looks like the legendary chickensh*t produced by novice welders. I usually end up ordering from a model supply company in Germany. Thanks for your kind offer – OK at the moment, but later would be good. If there is anything you think I might get around here for you, please e-mail.
For sure people in the UK don’t know when they have a good deal!
