Gipsy manifold material
Home › Forums › General Questions › Gipsy manifold material
  • #447561
    David K
      @davidk77137
      According to my plans the inlet manifold should be made of mild steel.
      looking at a couple of completed engines on the internet I notice one has used brass and another has used a mixture of brass and steel as the one pictured below.
      Is there any reason for using brass , as in the bottom plate on this one,
      #27085
      David K
        @davidk77137
        #447563
        old mart
          @oldmart
          It looks pretty.
          #447576
            And it does not show the silver solder joint
            #447579
            Steviegtr
              @steviegtr
              WOW. Very nice.
              #447634
              David K
                @davidk77137
                Stainless it is then.
                #447635
                  I think if I were doing it I would machine some stock down to 0.475" and then mill out the recess from below to 0.425" deep and then recess the bottom plate into the 3/8" wide passage so no joints are visible unless you are looking from underneath.
                  #447638
                  Anonymous
                    Depends on which engine, but on the Gipsy Major the inlet manifold was steel. It has two half pressings with a welded seam and individual steel plates welded on that bolted to the cylinder heads.
                    #447839
                    Tim Stevens
                      @timstevens64731
                      Brass has an expansion coefficient very close to that for Al alloys. The value for Steel is rather less. I suspect this might have been one factor in the mind of the bloke what made it.
                      Cheers, Tim
                      #447937
                      Paul Kemp
                        @paulkemp46892
                        Posted by Tim Stevens on 20/01/2020 18:19:24:
                        Cheers, Tim
                        Not sure I follow your thinking there? Steel top, brass bottom, sounds like a recipe for a banana to me? As it's the inlet manifold would it actually get hot enough over its length to make any appreciable difference? If it were the exhaust a different story maybe. If you are suggesting coef of ex to match the aluminium crankcase then that only holds good if the whole thing is brass?
                        Paul.
                        #447948
                          The lower tapered part down to the carb is aluminium but at such a small size I doubt expansion would be an issue and the suggested Araldite to join it would have enough flex to compensate.
