Fret (scroll) Saw
Fret (scroll) Saw
Home › Forums › Manual machine tools › Fret (scroll) Saw
Viewing 15 posts - 1 through 15 (of 15 total)
  • #373850
    Brian Abbott
      @brianabbott67793
      Hello all.
      Can i use a fret saw for cutting thin gauge steel, 1.5mm maybe 2.0mm ?
      Does anyone have any recomendations ?
      Thanks everyone..
      #13305
      Brian Abbott
        @brianabbott67793
        #373854
        Brian H
          @brianh50089
          What a good name Brian is!
          Is this a hand held or a powered fretsaw? Either way you need blades with enough teeth per inch to keep at least 3 teeth in contact with the job
          Don't see any problems though but don't push too hard.
          #373856
          Brian Abbott
            @brianabbott67793
            Hello Brian..yes not enough of us about these days.
            Powered ideally, so i need to find a fine blade ?
            #373857
            Ian McVickers
              @ianmcvickers56553
              Hand held saw then yes but it's slow work. Never tried it on a scroll saw but you might need some type of loose hold down to stop it pushing the plate up off the table but still allowing you to move it.
              #373858
              Brian Abbott
                @brianabbott67793
                Scroll saw, thats what i meant.
                Edited By Brian Abbott on 29/09/2018 20:23:22
                #373864
                the artfull-codger
                  @theartfull-codger
                  If your using a scroll saw your best of getting good quality blades,not too fine for thicker metal it'll cut it easily but you really need a saw with speed controll for cutting steel as the fixed speed saws are usually too fast. Look for piercing saw blades.
                  #373865
                  Brian G
                    @briang
                    Does your saw have blade clamps Brian? I'm not sure that the best blades are available pin-end.
                    Brian (yes another one)
                    #373869
                    roy entwistle
                      @royentwistle24699
                      I have often use a piercing saw on 1/32 Gauge plate for clock hands. Finest blade you can get and lubricate
                      Roy
                      Edited By roy entwistle on 29/09/2018 22:02:02
                      #373876
                      Cornish Jack
                        @cornishjack
                        Wouldn't imagine there would be any problem. Many years back at the ME exhibitions, Hegner used to demo their saws cutting intricate pieces in 3/8 brass so 1-2mm steel ought to be fine. Quality blades are importantthough. I bought (on recommendation) some Windjammer blades from the U.S. Pricy but good.
                        rgds
                        Bill
                        #373929
                        Ian S C
                          @iansc
                          I find a bit of candle wax best for lubricant. Sit down and take it slowly.
                          Ian S C
                          #374347
                          lfoggy
                            @lfoggy
                            I have a Hegner scroll saw and regularly use it to cut complex shapes in steel up to a few mm thick. Make sure you use a few drops of lubricant on the blade. The blades do break quite frequently but they are very inexpensive.
                            #374350
                            Martin Kyte
                              @martinkyte99762
                              Once you have blunted the small area of blade on contact with the work add a scrap of plywood packing with a suitable notch under the sheet to use a fresh part of the blade.
                              Personally I find it faster to do it by hand with a piercing saw frame and a notched sawing board clamped to the pillar drill table to bring everything to chest hight when working standing up.
                              regards Martin
                              #374351
                              Speedy Builder5
                                @speedybuilder5
                                I use a jig saw with a metal blade quite successfully. I place the sheet to be cut on top of some foam insulation and cut out the required shape (Foam and all). DO WEAR GOGGLES as the metal swarf is hot and has quite a range !!
                                #374371
                                Brian Abbott
                                  @brianabbott67793
                                  Thanks for all the the reply's, been away from a computer for a few days so sorry for the delay in thanking you.
