Flexispeed Tailstock Alignment – Realistic Expectations
Home › Forums › Manual machine tools › Flexispeed Tailstock Alignment – Realistic Expectations
Viewing 21 posts - 1 through 21 (of 21 total)
  • #830492
    James A
      @jamesalford67616
      Having realised that my Flexispeed tailstock was misaligned by a country mile, I have tried to realign it. I used a commercial test bar set between centres. I ran a finger indicator along the top surface and along the side to check alignment in both directions. I took several passes to try to average out measurements.
      The parallel section of the test bar, placed at the headstock end, was 90mm long. The maximum deviation along the top surface was between 0.02 and, occasionaly, 0.03mm. The maximum deviation along the side face was 0.02mm. Presumably due to wear in the lathe bed, the cross slide and possible dirt, these figures varied with each pass, but were still fairly consistent.
      Would I be unrealistic to expect anything better than this with a machine of this age and general quality? I do not mind trying to improve on these results, but not if I am chasing rainbow ends.
      James.
      #830500
      Bazyle
        @bazyle
        That’s a thou in real money – better than 90% of lathes out there I bet.
        #830503
        bernard towers
          @bernardtowers37738
          Not sure you are looking at this realistically considering the age etc. And have you really looked at homuch flex a 1mm drill has?
          #830507
          James A
            @jamesalford67616
            My reason for asking the question was whether trying to improve on my results would be realistic, bearing in mind the age of the machine. What would be considered realistic?
            Also, I am not sure how the amount of flex in a 1mm drill relates to the alignment of the tailstock. I realise that all drills have a degree of flex which is why I want to ensure that everything is as well aligned as possible to give the best chance of drilling a hole that is somewhere near central. Previously, it was so far out it was a problem.
            #830508
            James A
              @jamesalford67616
              Thank you.
              #830528
              cedric 1
                @cedric
                <p style=”text-align: left;”>Yes within a thou is actually quite good, considering the machine and age.  Carry on.</p>
                Beware of those test bars. Some are notoriously poorly made and will give you false readings. You can do a basic test by placing it between centres and rotate it by hand. Check with a dial indicator that it’s running true at several points on both straight and tapered sections.
                #830530
                Bazyle
                  @bazyle
                  Have a think about when you might need actual accuracy here. Not for drilling as an accurate hole would be finished by boring. Not for boring a cylinder as it is the bed ‘levelling’ that is important. It only matters if turning up a mandrel between centres which you do every day, er month, er year, er ?
                  #830555
                  bernard towers
                    @bernardtowers37738
                    You are after all looking at a machine that is possibly over 75 years old and was not a world beater then, perhaps if you are looking to use small machines you might be better looking at Shereline/ Taig or one of the asian offerings. then you can use quick change tooling and an array of accessories not to mention a good range of spindle speeds.
                    #830585
                    James A
                      @jamesalford67616
                      Cedric.
                      Thank you for the advice. I was not aware of that and shall do as you suggest to check that the test bar is not misleading me.
                      Bazle.
                      True. I do not turn between centres much at all, but it was doing so, followed by drilling a starting hole for boring that highlighted how far out the alignment was in the first place. I shall probably not turn between centres again for a long time.
                      Bernard.
                      The appeal of a new Sherline or similar is undeniable, but buying a new machine is not really an option. I need, really, to make the most of what I have.
                      James.
                      #830736
                      James A
                        @jamesalford67616
                        I tried this as suggested, although only on the parallel section. The taper is the wrong size for my machine so I can only use it between centres.
                        The bar is a little out of true, as Cedric cautioned. It ranged between 0.02mm and 0.04mm deflection when rotated by hand. With that in mind, I do not see any point in trying further to improve the alignment of the tailstock using the the bar.
                        If the minor misalignment does ever become a concern, I shall turn a test bar in situ and adjust using that.
                        James.
                        #830739
                        Dave S
                          @daves59043
                          You could chuck an indicator in the headstock and sweep the tailstock bore or a dead centre.
                          That’ll remove most of the not important variables – your comparing the axis of rotation of the headstock to the taper of the tailstock without a possibly dubious interposer
                          not done it yet
                            @notdoneityet
                            Presumably the original alignment was out by the proverbial country mile in the horizontal plane?
                            The usual practical check, for alignment, is by turning a bar, at each end, and comparing the finished diameters.  An unacceptable result would indicate in which direction the tailstock needs to be adjusted.
                            #830842
                            James A
                              @jamesalford67616
                              It was out in both planes.I shall turn a bar at some stage to refine the alignment.
                              James
                              #830874
                              not done it yet
                                @notdoneityet
                                James
                                The lathe effectively only removes material in the horizontal plane at a level very close to the centre height of the lathe.   Vertical difference between chuck and tailstock will make less difference.  Remember, too, that if you checked using a 3 jaw chuck, there will almost certainly be run-out at the chuck.
                                #830878
                                cedric 1
                                  @cedric
                                  Some better quality lathes are made with the tailstock several thou high, so that as it wears, it comes down into perfect alignment.
                                  So you can see that vertical misalignment of a few thou does not significantly affect the turning of parallel cylinders for general work.
                                  #830890
                                  James A
                                    @jamesalford67616
                                    Thank you for the replies.
                                    Not Done It Yet: I used a dead centre in the headstock taper and another in the tailstock.
                                    Cedric: That is reassuring to hear. Thank you.
                                    James.
                                    #830891
                                      What about using tailstock support when turning slender items, if the tailstock is off you could get a tapered part.
                                      Also consider that the 1thou off will be 1 thou if supporting say a short valve of 1″ length or a long column of 12″ so the amount of taper will depend on the length being turned.
                                      Maybe I do more in my workshop than others but the tailstock gets used for support both when the other end is in a chuck or when supported by a centre several times a year.
                                      #830895
                                        Also conside that if the error of 1thou is at the tailstock end when the barrel is retracted ( and locked?) and just a short dead ctr sticking out then it could be a lot more by the time you add the length of a drill chuck and drill bit which could magnify the error 10 fold..
                                        Doubt you will get much better than you have though.
                                        #830897
                                        James A
                                          @jamesalford67616
                                          It is just as you suggest, Jason. The barrel is retracted with a stubby little centre poking out. I shall run the barrel out to its full length and check the alignment again. I suspect that I shall not like the results……..
                                          James.
                                          #830926
                                          Bazyle
                                            @bazyle
                                            Good point, I do that without even thinking of it as having an effect and might even cause me to put the travelling steady off centre.
                                            #830972
                                            James A
                                              @jamesalford67616
                                              James.
                                              I have just measured the misalignment with the barrel fully extended and locked, as opposed to retracted and locked when initially measured. I was very surprised to find the there was no appreciable difference in either vertical or horizontal alignment. The results were essentially the same.
                                              James
