external frame rod drive diesel
Home › Forums › Locomotives › external frame rod drive diesel
  • #194301
    Perko7
      @perko7
      Newbie to both this hobby and this forum. Needing advice on preferred way of attaching counterweights to axles on a 5inch gauge rod-drive diesel with external frame. Thinking of press fit with keyway, but other options would be considered.
      #1415
      Perko7
        @perko7
        #194381
        Bazyle
          @bazyle
          Press fit might be a bit tricky for a beginner to get firm. Keyways too are tricky. Consider Loctite with a pin for peace of mind. Loctite can be used with as good a fit as you can manage easily (for alignment) but does not need to be so precise as a press fit, and does not actually need a gap (and hence slop) as mentioned in some of the older instructions. You can put in a tiny anular groove a thou or so deep if it helps to have a sort of reservoir for the loctite so you feel there is some there. If you screw up the quartering it can be got apart with heat.
          #226732
          Steve Addy
            @steveaddy35670
            I did Loctite and keyways on my loco. That was to get the quartering engineered into the axles and cranks.
          Home › Forums › Locomotives › Topics
