Elliott Omnimil 00 screw threads
Home › Forums › Manual machine tools › Elliott Omnimil 00 screw threads
  • #841995
    aviv
      @aviv
      Sorry for the basic question, but does someone know if the bolts in the Omnimil are or Unified?
      they are not metric for sure.
      Thanks.
      #842001
      Wade Beatty
        @wadebeatty78296
        I’ll go check
        #842004
        Wade Beatty
          @wadebeatty78296
          The belt tension holding bolt on the vertical head is 1/2 × 13 and one of the hex head bolts holding the flange for the horizontal drive is 1/4 x 20, both fit well on my 60 degree thread gauge set
          #842011
          DC31k
            @dc31k
            On aviv Said:
            …the bolts in the Omnimil are or Unified?
            There appears to be a word missing before ‘or’. Could it be Whitworth?
            Find something with a hexagon head on it. If a fractional spanner fits, it is likely unified. If it has some strange A/F dimension, it is likely Whitworth.
            Find something on it 1/2″ nominal diameter and measure the thread pitch.
            Find something on it with a fine thread and measure the thread pitch.
            #842013
            DC31k
              @dc31k
              On Wade Beatty Said:
              …one of the hex head bolts holding the flange for the horizontal drive is 1/4 x 20, both fit well on my 60 degree thread gauge set
              1/4 – 20 tpi is used both for Whitworth and unified. Your thread gauge test is incomplete as you did not assess the fit of the 55 degree Whitworth gauge.
              If you are trying to do science, please do it properly.
              #842017
              Wade Beatty
                @wadebeatty78296
                Oh! Einstein shows up!
                #842019
                Bazyle
                  @bazyle
                  An unified nut does not fit happily on a Whitworth bolt but works the other way round.
                  Worth knowing if you have a Boxford or SouthBend lathe as some bits don’t fit eg chucks.
                  #842021
                  Howard Lewis
                    @howardlewis46836
                    In addition to the thread form, the pitch may give a clue, as BSF or UNF
                    Unfortunately, BSW and UNC tend to have same pitches for the same size, but 1/4 BSF is 26 tpi where 1/4 UNF is 28.
                    5/16                                                 3/8
                    BSW   BSF   UNC   UNF                      BSW   BSF   UNC   UNF
                    18      22      18     24                         16     20       16    24
                    Although a good guide, don’t be too fixated on the hexagon size. Sometimes you can come across A/F headed Whit form fasteners; fortunately only very occasionally! I met a 5/8 A/F bolt with a 3/8 BSF thread!
                    #842027
                    Wade Beatty
                      @wadebeatty78296
                      A  1/4 x 20 NC nut fit on the smaller bolt and a 1/2 x 13 nut turned easy on the larger, also a 3/4 wrench fit fine on the hex on my mill.
                      #842138
                      aviv
                        @aviv
                        If you are
                        Indeed I meant to ask UNC or BSW. Fractional spanners fit well on the nuts and bolts. I will try to find 1/2 fastener on the mill and measure its TPI count with a thread gauge.
                        Aviv.
                        #842141
                        Bazyle
                          @bazyle
                          BTW are you a member of Groups.io/elliott
                          #842145
                          not done it yet
                            @notdoneityet
                            Don’t need Einstein!  1/2” is probably the only size that has different pitch between Whitworth and UNC.
                            Whitworth is 12 tpi, while UNC is 13 tpi.
                            OOPS.  Meant to quote Wade, not Bazyle.
                            #842155
                            aviv
                              @aviv
                              I’m afraid not. Could you share a link?
                              #842186
                              Bazyle
                                @bazyle
                                https://groups.io/search
                                One of the files of the parts diagram quotes table locking screw of 1/4 x20 UNC.
                                #842195
                                RobCox
                                  @robcox
                                  Having stripped down my Elliott Model 00 in the past to refurbish it I can say with all confidence that they’re UNC threads.
                                  #842196
                                  aviv
                                    @aviv
                                    Thank you all!
                                    #842197
                                    vintagengineer
                                      @vintagengineer
                                      Head size doesn’t always relate to thread size. Some early Morris cars had Whitworth headed bolts with metric threads.
                                      #842198
                                      Bazyle
                                        @bazyle
                                        Aviv, assuming you are new to the Omnimill it may be worth checking these previous threads for interest.
                                        https://www.model-engineer.co.uk/forums/topic/elliott-omnimill-00-axial-spindle-lock-ideas/.
                                        https://www.model-engineer.co.uk/forums/topic/elliott-omnimill-modification/
                                        #842234
                                        aviv
                                          @aviv
                                          Thank you.
                                          #842235
                                          aviv
                                            @aviv
                                            And BTW, I’m also looking for an original slotting attachment for the Omnimil, so if anyone knows about one for sale I would appreciate a link.
                                            Thanks.
