Hello All,
I wish to site a Myford ML10 lathe in my small shed/workshop. It will have to share the space with some woodworking and tool/timber storage etc. It arrives on Sunday
The lathe has a Myford drip tray of the standard type and riser blocks.
I’ll be constructing a timber bench to pop the standard type of Myford drip tray, riser blocks and lathe onto – as it doesn’t currently have a stand (and I wish to use materials I have to hand).
I have in mind that I’ll need to make the set-up stiff, to resist vibration and to incorporate some adjustability, to remove twist etc during initial set-up. There was a suggestion online that the riser blocks on the ML10 weren’t adjustable, effectively spacers for lathe height only? (I’ve ordered adjustable feet, for my as-yet-not-started bench, but could send them back if need be).
I’m hoping that you may have some suggestions to help me and other new ML10 owners get the most from the lathe: ML10 specific experience; coping with confines of a small shed and/or design details for the bench I’ll be building. Thank you in advance.
Starjump.
