Electric motor needed – from Where?
Home › Forums › General Questions › Electric motor needed – from Where?
  • #145627
    Stevo
      @stevo
      Hello all.
      I'm making a precision thickness sander (for Balsa and modelling timbers). I plan to rotate a sanding drum at 1500rpm.
      I've been looking for a (hopefully) secondhand electric motor, say 100-150W, single phase 1500rpm.
      Can't find one anywhere, unless you guys tell me differently!!
      #23174
      Stevo
        @stevo
        #145628
        John Stevenson 1
          @johnstevenson1
          Might tell us where you are from ?
          Bloke round the corner probably has one but which corner ?
          #145629
          Stevo
            @stevo
            Sorry John…. That's odd… I was sure I ticked the bit that said "show location" blush <embarrassed>
            Erith, in Kent, UK, by the Dartford Tunnel!
            Steve
            #145630
            John Stevenson 1
              @johnstevenson1
              This any good.
              Forgot to put a rule at the side but it's on an 11mm shaft so it's a 71 frame motor which means it 71 mm from base to centre. It doesn't have any feet but has the tapped holes.
              It's brand new, supplied and fitted in error [ should have been identical but 3,000 revs ] tatty as it been kicking about on a pallet for ages.
              If you want any the same but 3,000 revs I have shed loads.
              0.18Kw, 1/4 HP and 1350 revs single phase, ignore the 400v on the plate, that's the value of the cap.
              PM me if interested.
              Edit put 1/2HP down by mistake – damn keyboard………..
              Edited By John Stevenson on 01/03/2014 17:03:56
              #145631
              Martin W
                @martinw
                Hi
                Screwfix do cheap tile cutters with 400 – 500W induction motors, about £30 mark, though the speed may be faster than you have stated. The advantage with these is that you get the 'no volt mains switch' thrown in as well. If all else fails may be worth looking at one of these or similar.
                Cheers
                Martin
                #145632
                maurice bennie
                  @mauricebennie99556
                  Hi Steve ,Have a 1425 rpm 250 v 1/4 hp any good , I live at greenhithe near bluewater .
                  Maurice
                  #145633
                  Stevo
                    @stevo
                    Well this is a result..
                    Thank you both for your offers… I feel like I've just been offered an investment on Dragons' Den. Anyhow I have to choose one…
                    Maurice – I know Greenhithe… How much are you after?
                    #145635
                    maurice bennie
                      @mauricebennie99556
                      HI Steve A donation to RNLI would cover .Im at the top of mounts rd 97. In most days tomorrow do ?
                      Maurice
                      #145636
                      Stevo
                        @stevo
                        Wow Maurice..
                        I'll drop you a Private Message ..
                        #145747
                        Stevo
                          @stevo
                          Well done Maurice – good meeting you… your lathes… your milling machine….crying
                          Steve
                          #145748
                          Stevo
                            @stevo
                            Steve
                            #145749
                            Stevo
                              @stevo
                              Steve
                              #145750
                              Stevo
                                @stevo
                                Erm… what happened there…blush
                                #145798
                                Ian S C
                                  @iansc
                                  Don't worry most of us have done the same. Ian S C
                                  #145804
                                    @mike89748
                                    Back to the original subject and Martin W's post, when it comes to buying electric motors why is it often cheaper to buy a made-in-China machine and remove the motor rather than buy a motor on its own? When I needed to acquire a motor in the 250-300 watts range it was cheaper by far to buy a cheap drilling machine and, as Martin mentioned, I got a no-volt switch thrown in as well. What's more, the remains of the drilling machine is ace for aligning taps down pre-drilled holes. Crazy world, isn't it?
