Drummond round bed
Drummond round bed
Home Forums Beginners questions Drummond round bed
  • #219041
    Anthony johnson 1
      @anthonyjohnson1
      Hi is there any where that I can get gear wheels for drummond round bed lathe or can I adapt Milford ones the bores are the same
      #7945
      Anthony johnson 1
        @anthonyjohnson1
        #219056
        JOHN KNIGHT
          @johnknight56112
          Hi Anthony, I may well have some lurking in the garage. Give me a couple of days and I will seache them out.
          Bazyle
            @bazyle
            They appear every now and then on ebay uk. The characteristic pin rather than keyway slot marks them out but a couple of other rarer lathes did use the pin mechanism so just occasionally you might get a different one. Main thing is they are 14 DP So will not mix with Myford or Boxford ones. If you have none at all then you could consider using the alternative.
            Myford ones are 20DP so would be smaller and use a keyway rather than a pin so some adaptation would be r'equired, and sometimes you might need to put in an extra gear or two to fill the gap.
            Have you joined the Drummond yahoo group and seen Tony's site.
            #219086
            bodge
              @bodge
              Hi Anthony, A point to note is the pins are tapered ,so be careful if you need to replace any worn drive pins. They need to come out the way they went in !
              bodge
              #219278
              JOHN KNIGHT
                @johnknight56112
                Hi Anthony, I have sent you a PM.
