Drawbar Thread
Drawbar Thread
Home › Forums › General Questions › Drawbar Thread
  • #428274
    Steve Crow
      @stevecrow46066
      I need to make a drawbar for some homemade MT1 arbours for use on a Sherline.
      Now, looking a 8mm WW drawbars, I'm assuming that a fine thread would be advantageus.
      Is this correct or could I get away with a metric coarse thread? Just to save me buying fine taps and die.
      Cheers
      Steve
      #26824
      Steve Crow
        @stevecrow46066
        #428275
          Metric MT1 collets come with M6x1 thread so that should be OK
          If using comercal blank end arbors you may find they are threaded 1/4 x 20 Whit
          Edited By JasonB on 09/09/2019 18:24:10
          #428276
          Steve Crow
            @stevecrow46066
            Thanks Jason, I was hoping someone would say that! M6 it is then.
            I suppose the difference is that with the WW, you are closing a split tapered collet, hence the finer (40 tpi) pitch.
            #428285
              Yes less closing force needed on the smaller collets and the finer thread is not so deep which means the through hole can be larger
