Does round plastic drive belt warp?
Home › Forums › General Questions › Does round plastic drive belt warp?
  • #228655
    Rainbows
      @rainbows
      I got a bench drill where the V belt between the two pulleys will make a sort of oval shape when left on its own instead of a circle because it has formed itself around the pulleys. Does anyone know if polyeurethane round drive belt will do this as well?
      I have a plan where the belt will be tensioned by the weight of the motor driving it so the problem I was wondering about is whether the uneven belt will make the motor jiggle about and make everything shake.
      #24422
      Rainbows
        @rainbows
        #228656
        frank brown
          @frankbrown22225
          The round belting(green) I bought has got an extremely rough surface and runs my Geo Thomas drill with the belt being extremely slack.. The previous belt, round, red and smooth, just got rotted (by the sun?) and fell into many pieces.
          Frank
          #228663
          HOWARDT
            @howardt
            Shape that is formed by an non tensioned belt makes no difference to its performance when tensioned. Stockists often hang belts from a single point so will form oval while hanging in stock. So long as the belt has not perished and gone hard it should function well enough. Round belting is used for low torque applications.
            #228666
            Dave Halford
              @davehalford22513
              Posted by frank brown on 06/03/2016 19:15:00:
              Frank
              I had some red do that after 15 years in the cupboard, it's just age.
              #228713
              Ian S C
                @iansc
                All belts run at an oval shape, centrifugal force makes it bow out between pulleys. My first round plastic belts gave up after a few years back, from old age.
                Ian S C
                #228721
                MW
                  @mw27036
                  It's a shame you can't get the rubber vee belting that has a woven intermesh throughout, they last for years. But i dont know who'd sell it.
                  I'd strongly recommend having a way to bolt this motor to its set tension, belting relies on consistent tension in order to drive properly, the cutting forces could force the spindle to slow down because the belt will ride up.
                  Michael W
                  Edited By Michael Walters on 07/03/2016 08:59:37
                  Edited By Michael Walters on 07/03/2016 09:03:23
                  Edited By Michael Walters on 07/03/2016 09:04:49
