Correcting pilot error
Home › Forums › Beginners questions › Correcting pilot error
  • #68501
    David Haynes
      @davidhaynes53962
      Hi folks,
      Although I thought the centre pop was correct, I now find that the 1/8″ pilot hole does not quite lie on the intersection it should do. Final hole will be only a little bigger at 1/4″ dia. It will then be bushed and reamed. Not a lot of room for correction but any suggestions would be welcomed.
      Thanks, Dave
      #5515
      David Haynes
        @davidhaynes53962
        Correcting a pilot hole not correctly located
        #68502
        Dusty
          @dusty
          David
          If you have a milling machine or acess to one, then you could try setting it up with the hole in the correct relative position and use a 4mm slot drill to pull the hole into the correct position. This will not work with a drilling machine as it is not rigid enough and you need to be able to feed slowly, feed to fast and the slot drill will want to follow the original hole. This works best if the slot drill is new, an old blunt one is doomed to fail. By using a 4mm slot drill you have two more chances at correcting it with 5mm and 6mm slot drills. The other alternative is to set up in the 4jaw and bore it or use a slot drill in the tailstock.
          #68503
          Les Jones 1
            @lesjones1
            Hi Dave,
            The fact that you are marking out and centre popping makes me assume that you do not have a milling machine. If you did I would suggest using a slot drill. Assuming that you only have a drill press I suggest drilling a 1/4″hole in a piece of steel (Silver steel and harden it if possible.) and clamp this to the original piece of metal so that this will guide the drill to the correct position. More information would help other people to make suggestions. For example what equipment you have, the material you are drilling. the depth of the hole (And is it a blind hole.)
            Les.
            #68504
            ady
              @ady
              If you put the slot drill into a chunky 4jaw on a lathe and bolt the workpiece to the saddle, tighten the saddle gibs right up when you are happy with the drilling position then feed in nice and easy with the leadscrew. I usually peck drill.
              A Slot drill is definitely the way to go.
              #68505
                Posted by David Haynes on 15/05/2011 08:59:15:
                Hi folks,
                Although I thought the centre pop was correct, Thanks, Dave
                You should really dot punch first and inspect the mark to make sure it is correct before centre punching, if its not right then a light dot punch mark can be adjusted by tilting the punch and hitting again.
                If you can’t straighten it with a slotdrill then drill it to suit your bush but drill and ream the bush once it is pressed or stuck in position. In effect an eccentric bush
                Jason
                #68515
                mgj
                  @mgj
                  Would it be possible to weld (mig ideally) fill, or silver solder fill and just start again.
                  You haven’t specified what the object is, but if its feasible, adding metal for a fresh start is often a better solution than trying to take it out.
                  Sometimes, if strength is an issure, then a rough old screw thread carved in there will give a mechanical lock too- for SS or even loctite.(bush). Weld of course it will all be melted anyway.
                  #68516
                  MICHAEL WILLIAMS
                    @michaelwilliams41215
                    Loctite a pin of the same material into the hole , file flat , re mark out and re drill . Chose a drill size which is a little larger than previous pilot drill so that it effectively drills out the pin and leaves a new pilot hole in clean metal .
                    #68536
                    David Haynes
                      @davidhaynes53962
                      Thanks for all these respnses. The fault is in a 1/8″ thick flange on a gunmetal motion plate. I have a drill press and lathe, 3 and 4 jaw and vertical slide (for which I now recognise the limitations for milling!)
                      Thanks
                      Nicholas Farr
                        @nicholasfarr14254
                        Hi David, in which case I’d go for Micheal’s idea with the Loctite and pin, and then heed Jason’s advice about the dot punch.
                        Regards Nick.
                        #68543
                        John Baguley
                          @johnbaguley78655
                          Why not simply draw the pilot hole over to the required side with a round needle file, then redrill with a slighty larger drill. Check again and repeat the process as necessary until you are happy. That’s the usual method quoted for correcting an off centre hole.
                          David Haynes
                            @davidhaynes53962
                            Thanks all, I opted for drifting the hole and following up with slightly increasing diameter drills. The job is now spot on and no fussing about adhesive, filing or remarking.
                            Thanks again
