Peter
Its quite easy I have done it a few times the drive shaft as you say has a dog collar clutch sometimes with spring balls that you can lose easily..
The lead screw you remove the top off the gearbox and then there's a collar with 4 slots in it also with a grub screw to stop it undoing. You need to undo the grub and then unscrew the collar at the same time drawing the lead screw to the right hand side…make a note of which gear mates with which other gear on the gearbox row of gears..carry on removing the collar and moving the screw rightways when the collar is loose the screw will pull out be careful not to drop and spacers and the gears.
Oh and i seem to remember there's a circlip in there too
Oh and before you start loosen the collar at the far right hand side of the lead screw at the end of the bed
Its a bit fiddly getting it all back together but its just a reverse of disembly. I have a spare half nut if you need one
I have no idea on age but pre 65 if its a mk1
Edited By Ian Parkin on 17/10/2016 14:14:22
