CLARKE CL500 GEARS WANTED
Home Forums General Questions CLARKE CL500 GEARS WANTED
  • #520444
    steven dye
      @stevendye45808
      hi all im after a few clarke cl500 lathe screw cutting gears if anyone can help or advice somewhere to buy ive already emailed machine mart but imagine they will be pricey im after (32,36,40,42,49,50t then i can do few different pitch threads thanks ste
      #27896
      steven dye
        @stevendye45808
        #520447
        Oldiron
          @oldiron
          Put a wanted ad hereon this forum and other free sites like Homeworkshop would be your best bet.
          regards
          #520509
          Nicholas Farr
            @nicholasfarr14254
            Hi, you can always enquire here Clarke Service
            Regards Nick.
            #520514
            Howard Lewis
              @howardlewis46836
              If you measure the OD, of one gear you should be able to calculate the Module for the gears.
              I am assuming that the gears will be Metric and Module. OD in mm = (Tooth count +2 ) / Module
              Possible Module? 1.25 or 1.5 as purely a guess.
              Armed with that knowledge, and the thickness and bore of the gars, you stand a better chance of finding an alternative source of supply Recently, a friend was quoted something like 6 weeks for supply of parts for his CL500M., so other sources may be quicker and cheaper.
              I assume that you do not have facilities to cut your own gears, and you would have to file the keyway, if unable to broach it in some way.
              #522123
              David Taylor 25
                @davidtaylor25
                Hi did you ever get a set or find an alternative many thanks
