Citric is a very good pickling agent for model engineers. it will keep for months, (in a closed container to stop evaporation) and when it is no longer required may be safely poured down a storm drain, although a high copper content may not be welcome in a sewage works, depending on the ammount being disposed of.
As you use the solution, it will become blue with dissolved copper, but will still work fine. When it stops working,, say overnight, then it should be disposed of. If used to clean steel, it may deposit the copper onto the work, but this is easily removed.
Home brew stores sell larger quanties, up to one kilogram, but you should be prepared to prove that you do not want to use it to "cut" (dilute) strange & illegal chemicals.
Leighsteamer
