Changing Tapers on an Arrand boring head.
Home › Forums › Workshop Tools and Tooling › Changing Tapers on an Arrand boring head.
  • #414931
    Andrew Tinsley
      @andrewtinsley63637
      Right, I now have my Arrand Boring head with a 3 MT Taper. I also have the Arrand 2MT Taper.
      However I am blowed if I can undo the 3MT Taper from the head. There must be a simple way of doing this, but the mind is blank.
      Andrew.
      #19377
      Andrew Tinsley
        @andrewtinsley63637
        #414942
        ega
          @ega
          I believe these are just screwed in with a RH thread. So, essentially, grip the shank and give the head a sharp tap in the appropriate direction.
          I have done this successfully but don't remember the precise method. The shank could be gripped in the machine's own taper and the tap delivered via a suitably-gripped boring tool. The basic idea is to use the inertia of the shank against some shock loading to the head.
          I would guess that a boring head shank would be easier to remove than the same make of flycutter shank because of the intermittent action of the latter.
          Edited By ega on 18/06/2019 22:02:57
          #414944
          Mike Poole
            @mikepoole82104
            When all else fails the shank could be cut off and drilled out, I would regard the shank as expendable if it cannot be removed without risking damage to the boring head.
            #414945
            Andrew Tinsley
              @andrewtinsley63637
              Looks as though I may have to cut it off and drill it out. I have tried shock loading the head with the taper fixed and I am afraid I am going to do some damage if I hit the large spanner any harder!
              Thanks ,
              Andrew.
              #414946
              ega
                @ega
                PS It is possible to phone Arrand and talk to the proprietor's son though I don't know how far he could help. Posting this in the hope of anticipating your attack on the taper and will add the number if I can find it by searching the site.
                PPS See penultimate post here:
                https://www.model-engineer.co.uk/forums/postings.asp?th=94955
                Edited By ega on 18/06/2019 22:09:53
                #414970
                Brian Wood
                  @brianwood45127
                  Andrew,
                  They do unscrew, the thread is right hand. Try some heat on the head and a soak of the joint with WD 40 before you try the impact, it might just shock free then
                  It seems a shame to have to resort to drilling it out
                  Good luck.
                  #414973
                  Lambton
                    @lambton
                    Andrew,
                    I have an old Arrand catalogue dated 2003 in which it states –
                    "Boring heads have interchangeable shanks. Threaded interchangeable shanks are available (see chart opposite) so boring head can be used on machines with different tapers , or if you change you machine, a nrew shank can easily fitted to suit."
                    The "chart opposite) list a wide variety of shanks not just Morse taper ones.
                    Very unfortunately, Arrand ceased trading some years ago probably because of Far Eastern completion
                    Eric
                    #414979
                    ega
                      @ega
                      Posted by Lambton on 19/06/2019 09:17:55:
                      Andrew,
                      Eric
                      Agreed, but I gather they are prepared to sell such remaining items as they have in stock – see my post above for contact.
                      Edited By ega on 19/06/2019 09:57:36
                      #415104
                      old mart
                        @oldmart
                        Does your MT2 arbor have a male 1.5" X 18 thread? That size seems to be a standard for smaller boring heads. Arceurotrade sell replacement arbors with that thread. If so, the MT3 one could be replaced if you have to destroy it.
                        If there is a flange on the arbor where it screws into the boring head, a couple of flats could be milled in the flange to hold it securely in a vise. Then more torque could be applied to the head.
                        #415257
                        Andrew Tinsley
                          @andrewtinsley63637
                          Thanks everyone,
                          The shank has now been unscrewed! Perversely, I managed to unscrew it by hand. I think all the shock loading and heating persuaded it to surrender to mere unthreading by hand. I can assure everyone that it was stuck tight before.
                          Thanks,
                          Andrew.
