Posted by KWIL on 06/07/2012 18:43:03:
Phil, why did you not machine the triangular webs to the required thickness? I have machined them from solid before.
I tried that approach with one side of the horns but with a 1/8" diameter end mill (1/16" rad) the corners didn't look right at all. Also, the design uses 3/32" rivets which are way over scale size (31/2" gauge). So if the rivet heads look daft – I thought – why bother with the webs? In addition, the engine design uses Stephensons gear hiding one set of horns, the boiler ashpan hides the second set of horns and the valve spindle and gear hides the third set of horns.
I think (my view anyway) machining from solid would be ok at say 5" gauge with 1/16 rivets.
Do you have a picture of your machined versions?
Phil H
