casting copper hammer head ?
Home › Forums › Workshop Tools and Tooling › casting copper hammer head ?
Viewing 15 posts - 1 through 15 (of 15 total)
  • #162506
    Rich2502
      @rich2502
      I have come by a nice small copper hammer, with no copper inserts, how can I backyard cast the copper discs ?
      I have a propane torch, oxy propane cutter, firebricks, plaster of Paris, lots of scrap copper pipe, if any of that is use full.
      #17494
      Rich2502
        @rich2502
        #162507
        mike T
          @miket56243
          Richard, You can but new inserts from that well known auction web site. You could saw a piece off a solid copper billet. You could even buy a complete new copper faced hammer for less than the cost of all the gas and effort required to DIY… Unless you feel you must.
          #162508
          Rich2502
            @rich2502
            6 blimming pound each !
            I’m not made of money !
            Seriously , I don’t think it will take 6 squids worth of gas to melt a bit of copper.
            #162509
            jason udall
              @jasonudall57142
              Copper melts at 1083 ° C…probably casts at 1100…
              Compared to ali at 600 this will be a stretch.
              You will need
              A furnace. . ( white fire brick)…
              A crucible ..chose carefully. .you don't what it leaking ..on you feet say….
              A DRY.. repeat DRY mould…
              Something to act as flux to remove the oxides that will float to surface (Don't know what to use for copper)
              Old stainless spoon to scrape off the dross removed above…
              Suitable gloves…. see cruible above…
              ..good luck
              #162510
              jason udall
                @jasonudall57142
                I suggest weighing in a tenners worth of copper and buy the faces required..
                #162514
                  Is it a 'Thor'? You can get nylon and hide faces as well.
                  At £1266+p&p for 6" of 1" bar, £6 isn't a rip off.
                  Enough!
                    @enough
                    Posted by Neil Wyatt on 02/09/2014 21:15:24:
                    Hope there's a decimal point missing there!
                    #162529
                    Vic
                      @vic
                      No, he's from the future and prices have gone up a bit! surprise
                      #162533
                      Oompa Lumpa
                        @oompalumpa34302
                        Posted by jason udall on 02/09/2014 20:25:40:
                        ..good luck
                        I have discovered that ASDA have some very useful kitchen items. For instance they sell stainless steel containers/pots for £6 and these are useful for some of my blueing mixtures and there is a whole section of stainless spoons and stuff that can be made into ladles and skimming tools, even made a "dunker" for degassing tablets from a sink strainer. All for just a couple of quid.
                        Well there is my useless bit of info for the day.
                        graham.
                        #162534
                        Nicholas Farr
                          @nicholasfarr14254
                          Hi Richard, I personally don't think it is worth the effort. Buck and Hickman do replacemant faces at a reasonable price:- **LINK** and hide faces at **LINK**
                          Probably better to take your copper pipe down to the scrappy and buying new ones as Jason suggests
                          Hope this helps.
                          Regards Nick.
                          #162570
                          Ian S C
                            @iansc
                            Borax would probably be the flux to use, I'd try it. Ian S C
                            #162600
                            jason udall
                              @jasonudall57142
                              Prompted to try somthing….
                              Took copper blanking plug(Two) 22mm
                              Made short length of 22mm copper pipe. …I used 50 mm
                              Cross drilled middle of pipe one side.to allow gilling
                              Set on fire bricks..added lead …heat..melt add more lead..top up…..if filled carefully before heating you might not need to top up…but best be prepared
                              Cool…now have nicely annealed lump of lead filled copper……
                              Trials show copper durable and at least soft this far
                              Enlarge hole ..add handle..completed hammer..Haven't done this yet.( lacking suitable wood for handle to complete this idle thought project…)..but feels heafty
                              #162618
                              julian atkins
                                @julianatkins58923
                                as a slight aside i acquired a few copper stays removed from a GWR loco at tyseley many years ago, and these have been used by a few fellow club members to make copper hammers.
                                cheers,
                                julian
                                #162660
                                Bazyle
                                  @bazyle
                                  Do you really want copper as opposed to lead? Perhaps you could flatten some pipe, roll it up and glue it together with lead. Sort of compromise in hardness.
