Call me cynical / Call me thick … but
Home › Forums › Clocks and Scientific Instruments › Call me cynical / Call me thick … but
Viewing 23 posts - 1 through 23 (of 23 total)
  • #3919
        Someone please explain how the length of a second can be measured more accurately than its definition
        https://www.smithsonianmag.com/smart-news/new-atomic-clocks-hone-length-second-180977387/
        dont know
        I guess the answer lies in the semantics … and that “Time” is not quite the same thing as our defined method of measuring the second.
        Note: I haven’t yet read the published paper … it may make more sense when I do
        #538324
        Circlip
          @circlip
          The space/time continuam is regularly distorted by Q.indecision
          Regards Ian.
          #538330
          jaCK Hobson
            @jackhobson50760
            Isn't it just saying how a second is defined? So the new definition of using the frequency of some alternative atom is found to be more consistent under different conditions.
            Like a foot used to be the length of someone's foot but as they change a bit from person to person, a more universal definition has been chosen.
            An inch might have been the width of a thumb but got redefined to make it be easier to map onto metric.
            Temp scale has had a few changes, some quite recent.
            #538333
            Rod Renshaw
              @rodrenshaw28584
              +1 for Jacks view. The article seems to be saying "they" have found that several different atoms give slightly different results and in due course there may have to be a reconsideration of what is the most useful way to define the second. It's happened before, but it seems unlikely that any non-specialist will notice any difference.
              Rod
              #538334
              JA
                @ja
                It does not make any difference to me. Time is something I loose by not being in the workshop. As I get older it speeds up.
                I believe mass is now defined by the number of atoms in some lump of metal (I bet it is not cheap mild steel).
                JA
                #538341
                Robert Atkinson 2
                  @robertatkinson2
                  In my home workshop I can measure time to 20 picoseconds for one off events, much better for something that can be averaged. Thats 2×10^-11 or 0.00000000002 s. Thats good enough for most practical purposes. Light travels about 6mm in 20 ps.I can measure frequency to over to 25 GHz (2.5s10^10). I have 4 atomic frequency standards, but like most time nuts I mostly use GPS based clock. I have several of those with 3 different models running 24/7. You need three because if you only have two and they are different you don't know which is right nerd
                  I built a precsion quartz oscillator at over the weekend. I can easily see the effect of gravity on this e.g. the frequency change when you turn it on its side, +1 G to 0 G
                  Robert G8RPI.
                  #538352
                  Ady1
                    @ady1
                    Time is like a toilet roll, the older it gets the faster it goes
                    #538355
                    Andrew Tinsley
                      @andrewtinsley63637
                      If the selected atom outputs light at a given frequency then the higher the frequency then there are more subdivisions of time available and hence greater potential accuracy..
                      Ignore Roberts quip re difference in gravity and hence frequency if his oscillator is upright or on its side. However time does alter depending on gravity. A satellite born atomic clock will give a different time to one on the ground . This has to be taken into account for GPS location otherwise the system will give an incorrect result.
                      Andrew.
                      #538357
                      Robert Atkinson 2
                        @robertatkinson2
                        Posted by Andrew Tinsley on 06/04/2021 14:40:36:
                        Andrew.
                        It was not a quip, the oscillator I was refering to is a quartze one (HP 10811D based) and it has a detectable change in frequency when turned on its side or inverted.
                        Robert G8RPI.
                        #538362
                          Posted by jaCK Hobson on 06/04/2021 11:31:11:
                          I have no problem with that situation, jaCK … but my question was a little more philosophical
                          If we currently have a definition of the Second …
                          how can they claim to have measured it more accurately than that ?
                          [quote] Researchers used three atomic clocks to measure time accurately down to the quadrillionth of a percent [/quote]
                          Edited By Michael Gilligan on 06/04/2021 15:35:08
                          #538372
                          Phil Stevenson
                            @philstevenson54758
                            Posted by Robert Atkinson 2 on 06/04/2021 12:50:04:
                            A man with one clock always knows what time it is. A man with two clocks is never quite sure.
                            #538389
                            Robert Atkinson 2
                              @robertatkinson2
                              Posted by Michael Gilligan on 06/04/2021 15:22:14:
                              The actual experiment was more about different means of time transfer, fibre optic vs direct ( free space) laser than the actual references themselves. The problem is that it takes time to transfer the time from one place to another. Even in the time of clockwork noon at Greenwich was signalled by both sound and visual signals as sound takes too long to travel. Thransferring time long distances relied on radio but even this has delays. When HP desigined the 5061A "transportable" cesium beam frequency standard in the early sixties the enabled "flying clocks and accurate time transfer around the world.
                              https://www.hpmemoryproject.org/news/flying_clock/celebration_01.htm
                              Robert G8RPI.
                              #538392
                                Take heed from one who found out the hard way! Accurate time is highly addictive, whether by clockwork or electronics. Sucks you in with promised delights, spends all your money, and nothing you do is quite right. Bit like marriage really…
                                Robert Atkinson 2
                                  @robertatkinson2
                                  Tell me about it. 6 GPSDOs, (one Rubidium), 4 other Rubidium oscillators, LF off-air standards, GPS receivers, crystal oscillators (some cost thousands of pounds when new) about 10 frequency counters including HP 5370B and Philips PM6654, the list goes on….
                                  Robert G8RPI.
                                  #538430
                                  Andrew Tinsley
                                    @andrewtinsley63637
                                    Robert, you have some very strange ideas on gravity. Turning an oscillator on its side does not change gravity from 0 G to 1 G
                                    I have specialised in the study of relativity and gravity for the last 50 years and you are just plain wrong.
                                    Andrew.
                                    #538444
                                    John Haine
                                      @johnhaine32865
                                      But it could easily make a wire move a micron or so – unless it has strain relief.
                                      #538463
                                      Robin Graham
                                        @robingraham42208
                                        Posted by Michael Gilligan on 06/04/2021 11:05:16:
                                        dont know
                                        Michael – as I suspect you suspect, the author of the Smithsonian mag article is a bit woolly in his thinking and reporting. He somehow seems to suggest that 'the second' is an objective entity which can be measured, but he doesn't make a clear distinction between definition and measurement. His background is in is in biology/ecology, so perhaps that's not surprising.
                                        The article in Nature on which his report is based is certainly interesting, – thanks for drawing attention to it.
                                        Robin
                                        #538465
                                        steve de24
                                          @stevede2433577
                                          By far the best discussion re the nature of time is given here :-
                                          GS1
                                          Enjoy.
                                          #538485
                                            Posted by Robin Graham on 07/04/2021 01:49:21:
                                            Robin
                                            Nicely put, Robin … We are ‘on the same page’
                                              Posted by steve de24 on 07/04/2021 02:24:31:
                                              GS1
                                              Enjoy.
                                              Fond memories yes
                                              I’ve just sent that link to our son [currently out in Laos], to see if he can explain it to the locals.
                                              Howi
                                                @howi
                                                Robert G8RPI.
                                                Someone has far too much time on his hands me thinks…………
                                                on second thoughts………
                                                but then how do I measure that?
                                                time I was going……….
                                                OMG I have just wasted two minutes of my life Aarrgh! panic.
                                                #538540
                                                Martin Kyte
                                                  @martinkyte99762
                                                  Even assuming the absolute stability of the atomic oscillator the second is defined as a fixed number of transitions and using this as a reference imposes a limit on the subdivisions or granularity of any time measurement. One cannot subdivide time into smaller units than the oscillator period. A faster oscillator allows better time resolution which is what I think the article is getting at.
                                                  regards Martin
