Bore Measuring Gauge
Home › Forums › General Questions › Bore Measuring Gauge
  • #456749
    Chris Pocock
      @chrispocock
      Morning,
      We are looking for a Bore Measuring Gauge for measuring the barrel of a plastic extrusion extruder.
      It would need to measure 50-80mm ideally and have a depth that you can measure at to be around 1 meter.
      We are struggling to find anything that long without paying silly money as we will only use it a couple of times a year at most.
      Thanks.
      #27200
      Chris Pocock
        @chrispocock
        #456752
        David George 1
          @davidgeorge1
          When I had to measure wear on hydraulic cylinders we used a dial indicator type bore gauge where you set the diamiter with a micromiter and read of the difference on clock face. Mercer or Oxford make similar and we had one that would check up to 2 meter length with extensions. Oxford2.0-6.0" Dial Bore Gauge from Zoro £95.00. But you would have to add on extensions.
          David
          #456815
          Nick Hulme
            @nickhulme30114
            That kind of Metrology is available to rent.
