Boiler construction
Boiler construction
Home › Forums › General Questions › Boiler construction
  • #630927
    Garry Coles
      @garrycoles69390
      Hi, I want to buy a copper boiler for a 5in gauge loco that I will be building. I've had various quotes that have ranged from £3100 for TIG welded to £6500 for silver soldered. My question is, what are the pros & cons for silver soldered or TIG welding. Which would you recomend.
      Garry
      #29012
      Garry Coles
        @garrycoles69390
        #630932
        Luker
          @luker
          Hi Garry,
          The main difference, as you pointed out, is cost. The joint design for the two different boiler construction methods needs to change, but provided the boiler is designed for the specific joint construction method there will be no difference. I have designed and built both TIG and silver soldered boilers and both work perfectly. My personal preference is TIG due to cost, and the fact that a crown stay is safer to construct using TIG (silver solder could let go when heating the stays in the firebox, and has happened once to me. A mission to fix!).
          BTW those prices are ridiculous! You can buy a decent second hand vehicle for that (in my neck of the woods)…
          #630934
          Dave Halford
            @davehalford22513
            Ask TIG at the track that you wish to run on.
            #630935
            Brian Baker 2
              @brianbaker2
              Greetings Garry, ask the boiler inspector at the club you wish to run at,
              regards
              Brian B
              #630936
              Garry Coles
                @garrycoles69390
                I live in Jersey and as far I know there are no model boiler inspectors over here.
