Big lumps of Cast Iron
Home › Forums › General Questions › Big lumps of Cast Iron
  • #27230
    nigel jones 5
      @nigeljones5
      #459980
      nigel jones 5
        @nigeljones5
        As a hobby project (as well as the 1:6 ratio WW2 Tank build!) im making a quite large Compound Stationary engine. I need some biggish lumps of cast (hate ali so not using it) for the base and cylinders, roughly a 6 inch cube would do. Before goung to a foundry and having things made for me I wanted to see if anywhere sold these things off the shelf. I can get ingots but thats no use to me. Any suggestions please?
        #459982
        Nick Clarke 3
          @nickclarke3
          College Engineering Supply in Tipton in the West Midlands list 150mm and 200mm square
          David George 1
            @davidgeorge1
            Try M Machine Metals they cut to size and Usualy quick delivery. http://www.m-machine-metals.co.uk/
            David
            #459991
            Dave Halford
              @davehalford22513
              Rapid Metals do huge blocks of cast iron, a tidly 6" cube might be in the scrap box Currently closed due to our daily nightmare.
              #460006
              Iain Downs
                @iaindowns78295
                I think Metals for U also do cast iron in large sizes.
                Iain
                #460011
                Paul Lousick
                  @paullousick59116
                  Round sections of commercial cast iron bar are more readily available if you cannot get square. It would be cheaper than having something specially cast.
                  Paul.
                  #460204
                  lfoggy
                    @lfoggy
                    I purchased a peice of cast iron around that size on ebay last year. It was an offcut from a workshop. Not that expensive either.
                    #460226
                    noel shelley
                      @noelshelley55608
                      If you know what you want and can make a pattern then a casting would be the way to go ! If the idea appeals and you need help PM me, it could save a lot of machining.
                      Best wishes Noel.
                      #460266
                      Chris Evans 6
                        @chrisevans6
                        You only need to make a polystyrene pattern for one offs, I do so often. Biggest problem is finding a foundry that will do a cash job.
                        #460431
                        Howard Lewis
                          @howardlewis46836
                          Not a lot of good while we are all confined to barracks, but if you can manage with something less than a 6" cube, I have bits cut from a fairly hefty engine flywheel that you could have, just to liberate the space.
