Yes; Cerrobend (now called CS Alloys Bend 158) will do the trick. I use it for bending thicker walled steel pipe, but it is easy to use and will avoid all kinking and distortion of the tube. You may still want to use a spring or a bender with formers, but the Cerrobend will still prevent damage. I use it in steel to allow bends with much tighter radii than can be achieved using a conventional former-style bender. In fact, I use the kind of bender that is normally used for flat bar or solid circular bar, and can get tight bends.
You can get small quantities on eBay. It is relatively expensive, but is designed to be re-used.
Melt it in boiling water, a bit at a time, then pour it into the tube. Let it set (doesn't take long); bend the tube, then heat the tube and the Cerrobend runs out. I run it into a tray normally used in the oven for making cupcakes, so I end up with little thick pancakes of the material, which go back into the drawer afterwards, ready for next time. You don't want a big solid lump because although it melts at a low temperature, it takes ages to metl a lump in boiling water. I dare say you could melt it with a hotter source, but the fumes are injurious, so a layer of boiling water helps keep the fumes at bay. face mask, goggles, and outdoor working are my recommendation.
Jolly handy stuff.
Marcus
