Bandsaw blade base
Bandsaw blade base
Home › Forums › General Questions › Bandsaw blade base
  • #24450
    Col21
      @col21
      #230857
      Col21
        @col21
        Hi quite new to this forum. Was looking for some advice on what to do with my bandsaw base where the blade comes down on. Pictures below. I've got a bridgeport type milling machine that I've thought about using to machine flat but don't know how to secure a new piece of metal in. Or should I try and weld it back up then machine. Just so it looks better on the eye. Wondering what ideas you boys have. It's cast iron. Thanks in advance.
        #230858
        Col21
          @col21
          #230859
          Col21
            @col21
            #230877
            Jeff Dayman
              @jeffdayman43397
              why bother? spend your time building something fun and/or useful
              #230887
              Brian Wood
                @brianwood45127
                I would set an auto off switch in the system somewhere to take care of that
                #230993
                Lambton
                  @lambton
                  Fit in a piece of MDF that can be changed easily and as often as necessary. This will also save a little wear on the band saw blade.
