I replied to the "elmer's engines" thread a while ago with the note below:
C – close fit
S – smooth finish
P – press fit (or Pray it fits) – sometimes PF also used
SF – slip fit
LF – loose fit
B – braze or silver solder
F – make flat
SWT – seal watertight
SGT – seal gas tight
W – weld
H- harden
H&G – harden and grind
These conventions were and are used on some North American tooling drawings as guides for skilled toolmakers. Many old timers I worked with would see specified tolerances on tool drawings as an insult to their skills in making and fitting a machine to work as expected, and preferred to see the notations above used rather than tolerances.
http://www.john-tom.com has free PDF files of plans for several of Elmer Verburg's engines.
When I used to work for a large USA based controls company in their tool design office we came up with several unofficial variations on the above symbols over the years, as below:
RF – rust fit -as in when a steel shaft is turned too small, leave it outdoors for a week, then the rust coating will allow it to fit right
PH – not just a press fit, Pound Hell out of it.
LAMW – loctite, after machining it wrong
GIRD – get it right dummy (it's important) as applied to an important dimension
WWD – weld without distortion (ie perform distortion control measures) but this was interpreted as "weld when drunk" a few times.
Have fun with the Tiny. Elmer's engines are great.
JD
