Any ASME welders out there?
Home Forums Beginners questions Any ASME welders out there?
  • #85921
    nigel jones 5
      @nigeljones5
      Hello
      I will soon need my 5" boiler welding by someone with the right papers (if you have them you wont need me to tell you what they are). Im more than willing to pay for your services, and can travell however far it takes. Any offering to help??
      #5987
      nigel jones 5
        @nigeljones5
        #85925
          I may be wrong and its a bit of a grey area but once you start paying someone to do the work it becomes a professionally made boiler. And if its a private job make sure your welder actually holds the code himself and not teh company employing him, also needs to be coded for that type of work.
          Did you find an existing design in the end as thats quite quick if you had to get the design approved.
          J
          Edited By JasonB on 26/02/2012 21:05:38
          #85936
          Weldsol
            @weldsol
            I think Jason is correct if a payment is made wether it is money or payment in kind it would be deemed a professionally made boiler and as such would require CE marking (depending on Bar / ltr capacity)
            Also the person holding the certification would need to produce his insurance details to say that they accept the liability on his behalf.
            You can hold certification without being insured. (it's the insurers that want proof of capability )
            One way you could look at it if a fellow club member holds the certification and he welds your boiler for no payment what so ever and the club inspector accepts this then the boiler should be ok for the club insurance.
            As for coding he will need to hold the appropriate code say EN287 or ASME 9 for the correct material , cover the diameter range, the joint type, correct welding process , and correct welding position.
            Your other option would be to do some test welds in front of your club boiler inspector get them tested then weld your own boiler. ( proof of being a competent welder)
            Paul
            #85941
            nigel jones 5
              @nigeljones5
              tyhanks guys, i spent many years as a coded welder so i apreciate the legislation…just need to find someone in the northwest who wants to help – amounts to about 5 minutes welding if that!!
