Hi All.
Just had my first attempt at making a backplate for my ER25 collet chuck from Arc. Not exactly a trouble free experience!
First I checked the external spindle of my M7 and it showed about .02mm either side of 0 runout on my Mercer METRIC .01mm dial gauge.
Put the backplate on the spindle and tried to true up the outer rim. There must have been a really hard patch on it somewhere, screeching and chattering like mad, so changed the speed and took a heavier cut which finally got through it into somethng more docile but it did not like HSS at all so tried carbide which was better. Facing was no problem at all and slowly crept up on the correct size register to ;just fit' with a light tap or two.
Realising that I wanted to counterbore (another first!) I measured what I had available that would suit the M8 cap screws and then drilled backplate on the mill with 6.3mm to suit the c/bore pilot. This was not straight forward as the pilot somehow jammed into the hole and detached from the c/bore shaft and stalled the machine! Managed to drive it out and did the other two holes using the pliot to line up and then removing it for the drilling. Kind of OK but I could see the c/bore wandering a bit. Also tricky to line up the other holes as my vice is barely big enough to hold th plate securely so used tool clamps as backup. Finally driiled through 8.2mm clearance.
The whole operation felt 'untidy' which was not what I was hoping for trying out a new process.
Putting the chuck on the spindle and using a Verdict 0.0005" indicator in the taper of the collet chuck I get a variation of 4 units either side of 0 so I guess thats 2 thou either side? Does not sound great but not sure what it should be.
If this is unacceptable where do I go from here please?
Not a nice feeling trying hard to get it right and being disappointed with the outcome but I guess this is how I learn..
Martin
