A Santa Special to forget.
Home › Forums › The Tea Room › A Santa Special to forget.
  • #35703
    martin perman 1
      @martinperman1
      #443814
      martin perman 1
        @martinperman1
        Gentlemen,
        Me thinks that somebody had his knuckles wrapped, https://youtu.be/OUzgkAGZ3aI
        Martin P
        #443823
        Emgee
          @emgee
          That's a shame, more work for the restorers. Were does responsibility lie in such cases ?
          Emgee
          #443977
          Brian Sweeting 2
            @briansweeting2
            Posted by Emgee on 29/12/2019 23:50:22:
            Emgee
            Looks like the didn't check couplings properly.
            #443979
            Jeff Dayman
              @jeffdayman43397
              In the UK, is the engineer/driver ultimately responsible for the tender to train connections/coupling if he made it? Or is there shared responsibility with engineer/driver and fireman?
              If a trainman from the yard or depot made the connections/coupling and engineer / fireman did not, the trainman becomes responsible, I expect.
              Repairs are likely not too involved but any damage to restored equipment is a heartbreaker to the volunteers doing the work.
              #443982
              Dalboy
                @dalboy
                I did like the bloke who walked up took off his flat cap and scratches his head as though to say "How the eck did that happen"
                #443986
                Hopper
                  @hopper
                  It looks like the couplings, brake hoses and safety chains etc were all disconnected and stowed, so possibly done deliberately? Did they just forgot to disconnect the gangway cover between the doors on the two carriages? Or did they manage to ignore all those disconnected and stowed brake system hoses before taking off with disconnected coupling? Surely there would be an SOP to check such before moving out?  If not, I'd bet there will be now.
                  And is that the Fat Controller stepping into the foreground about three-quarters of the way through? I'm sure he had something suitably stern to say.
                  Edited By Hopper on 31/12/2019 02:20:30
                  #444000
                  Nick Clarke 3
                    @nickclarke3
                    One can possibly sympathise a bit with the person who uncoupled the train – They had probably done exactly what they should have done, just as they had been trained and quite likely in the correct order too – but did their training include the corridor connection as that is only found on a Gresley tender?
