Making Holes in Copper Sheet
Home › Forums › Beginners questions › Making Holes in Copper Sheet
  • #405660
    Steve Withnell
      @stevewithnell34426
      I need to make two holes in copper sheet, nominally 22mm. Nominally, because I want the hole to be a push fit for a selected piece of 22mm copper waterpipe.
      One sheet is 1.5mm thick and 55mm diameter overall and the other 3mm thick and 105mm diameter. (If you read the same magazine that I do, you will know what this is for )
      My plan was to sandwich each sheet between two pieces of 18mm ply and clamp it down onto the mill table, then drill out to 19mm. Then use a boring tool to creep up to the push fit diameter.
      The questions – is this the best way of achieving the goal? What do I need to manage to ensure a nice clean hole and what spindle speed should I run the boring tool at?
      Many thanks in advance
      Steve
      #9626
      Steve Withnell
        @stevewithnell34426
        #405664
        John Olsen
          @johnolsen79199
          I would probably use a hole saw for the initial hole, still using the bits of ply as you intend. Ordinary drills are not always very good on sheet metal. Otherwise a step drill or a conecut would make a better job on sheet metal than a normal drill, but they can be a bit expensive if you don't already have one.. Using a boring tool, either a boring head in the mill if you have one, or boring in the lathe should be a good way to get the final size. Take it gently with all the work, copper can be a bit grabby at times.
          Don Cox
            @doncox80133
            A search of eBay "Holesaws" turns up loads of suitable 22mm cutters for about £3, use the clamped ply idea to keep it all flat and try a nice slow speed to start off with.
            #405670
            vintage engineer
              @vintageengineer
              Q Max punch will give you the neatest holes.
              #405674
                Adjustable tank cutter? Or Qmax type (may not be rated for 3mm and the ‘nominal’ size may not be quite as ‘nominal’ as you might want) smiley Nominal size of 22mm pipe may not be quite 22mm exactly, but could be swaged to fit? I clearly don’t read the same mag as you, so no idea how far you might want to push this pipe through the hole.
                The methods suggested above but I think I might cut into something more robust under the sheet.
                #405678
                Paul Lousick
                  @paullousick59116
                  Step drills are designed for making holes in sheet metal. Available is a range of sizes. Drill to nearest hole size and finish by hand with a round file if necessary. (Hole size can also be enlarged with a taperred reamer).
                  Paul
                  Edited By Paul Lousick on 19/04/2019 11:46:36
                  #405679
                    Clamp it to the faceplate in the lathe and trepan it with a parting-tool-like trepanning tool then finish to size with a boring bar? Or avoid trepanning by drilling a small hole in the middle and facing outwards with successive cuts to near the finished size then bore to finish.
                    Spindle speed? 400rpm or so should do the job.
                    Edited By Hopper on 19/04/2019 11:45:38
                    #405692
                    Steve Withnell
                      @stevewithnell34426
                      Thanks folks. I've so much going on I'd forgotten I had a set of step drills, if they won't go all the way, I can use a boring bar to get to a push fit with the pipe. The pipe is very short (it's not a plumbing job) around 20mm and needs to be a precise fit, which is why I thought about teasing out to size with a boring bar.
                      Will report back…
                      Steve
                      #405698
                        Step drills are ideal for this sort of job and much under-rated. As thyey have no rake they are less likely to grab, but do secure the work.
                        Guy Lamb
                          @guylamb68056
                          I too would use a tank cutter, perhaps sandwiching the work piece in between a couple of scrap copper to minimize
                          any burring. Hole saws tend to 'rag' when cutting copper I've found.
                          Guy
                          #405733
                          Jon Lawes
                            @jonlawes51698
                            Q max would be my vote too, even home made.
                            #405738
                            Phil Whitley
                              @philwhitley94135
                              may not be suitable for your purpose, but if you drill a smaller hole for a length of threaded rod, and the select a couple of sockets from a socket set, the smaller having the external diameter of the hole you want, and able to fit inside the larger with a reasonable ammount of clearance, assemble them onto the threaded rod with one socket on either side, and tighten the nuts thus forcing the smaller socket through the sheet and into the inside of the larger one, you will find you can form a very usable socket into a flat sheet. I have done this in steel, aluminium and copper. Anneal it first! you could even turn up a couple of dies on the lathe, but I have found that sockets work just as well, provided you can find the correct diameters.
                              #405763
                              John Reese
                                @johnreese12848
                                I have a set of these:
                                They work really well on sheet metal. For brass I had to dub the points. They will probably work as is for copper. Expect the holes to be a bit oversized due to runout of the cutter.
                                #405767
                                Boiler Bri
                                  @boilerbri
                                  I use rotabroaches. They quite cheap on fleabay. You have to have a 3/4" collet though. They cut very accurate holes.
                                  Brin
                                  Edited By Boiler Bri on 20/04/2019 09:00:30
                                  #405769
                                    Posted by Boiler Bri on 20/04/2019 08:59:15:
                                    http://www.rotabroach.co.uk/cutters/
                                    Interesting to note that they also do 'Mini Cutters' yes
                                    Former Member
                                      @formermember19781
                                      #405773
                                        Step Drill for me, think the one at the back in this photo was 16mm, if you need a really accurate fit then do the last step with the boring head – sharp tool sped as you would if turning 18mm dia in teh lathe but may have to be less if the head is off balance.
                                        #405948
                                        Nigel Graham 2
                                          @nigelgraham2
                                          Steve's question shows the hole has to be quite accurate.
                                          Whilst a hole-saw will rough out the bulk of the metal, even the rigid-bodied type will NOT give an accurate hole! They are not designed to do that, they leave a rough-walled hole, and tend to run eccentrically. Also, most of the readily available ones are sized for standard water-pipe and electrical conduit material in applications not needed a close push fit.
                                          The older type of hole-saw, consisting of a ring of bandsaw-blade clipped into in a groove in the face of a large bush, is even less accurate.
                                          Do use hole-saws, but be aware of their limitations, and use one generously under-size to leave accurate finishing by the various techniques described above.
                                          A step-drill in a decent machine-tool may give the fit you need for the particular work-piece: try on an off-cut first.
                                          A cone-drill can be used with care to give a tight fit, but obviously the hole will be tapered and diameter control is difficult. The significance of the taper will be controlled by the material thickness and the fit required.
                                          Step-drills and cone-drills are not desperately costly from places like Screwfix and Toolstation (which also sell hole-saws), and very useful tools indeed. Assuming appropriately matching diameters of work and tool and the fit requirements, they can leave a finished-size hole needing no more than as the drawings say, removal of burrs and sharp edges.
                                          I use all of the above for various tasks, obviously depending on material and purpose, and have even roughed out holes through thick plastic with a hole-saw, though that was somewhat fraught process as the tool is really intended for thinner and slightly harder materials than an inch of soft thermoplastic (PVC)! I did that 'cos I wanted to keep the central slug as bound to come in handy one day…
