Mach3 / KX1 Erroneous Limit Switch Detection
Home Forums CNC machines, Home builds, Conversions, ELS, automation, software, etc tools Mach3 / KX1 Erroneous Limit Switch Detection
  • #848270
    Steve Withnell
      @stevewithnell34426
      My setup is as shipped by ArcEuroTrade some years back.    Dell desktop running XPSP3 and the locked down version of Mach 3 that came on the disk.   Vectric Cut2D has coped with everything I’ve done so far, which has been fairly wide ranging.   This set up has never missed a beat so far.
      This week I set out to do a very simple job, a small instrument panel ten 5mm holes for LED’s and then engrave the LED function underneath.
      The engraving job triggers an emergency stop from a false limit switch detection at random intervals.    I discovered that the software debounce settings ‘as shipped’ was set to 0,  and this has never been an issue.   Anyway I’ve upped that to 6mS and the fault remains, sooner or later the engraving job triggers a false limit switch detection.
      I’ve waggled all the drag lines to the switches with the machine running and I can’t force this problem.
      Next step will be to put some decoupling caps on the inputs to the Mach3 PCB,  but I don’t have a schematic or annotated photo of the USB version of the Mach3 control board.
      I understand this issue is well documented in this and other forums, but my searches don’t pull anything close.
      Any ideas please?
      #848285
      Jim Guthrie
        @jimguthrie82658
        Just a note on what happened to me a month or so ago.  With pretty well the same setup as you having purchased the KX1 from Arc Euro with the bundled Cut2D.
        I was cutting with a 2mm slot drill and all was well.  I then had to change to a 0.5mm slot drill to finish off some small details and I started to get intermittent limit switch operation.   After a bit of consternation,  the cause dawned on me.
        I normally work with a 18mm spoil-board on the table but in this case I had opted to work with the workpiece clamped directly to the table.   I use an ER25 collet to hold my cutters.  With the longer 2mm cutter in use,   there was no problem,  but with the shorter 0.5mm cutter,  the machine was hitting the Z limit switch when lowering to do its cutting.
        This was hidden from me since I use an auto height setter which is about 25mm tall,  so auto height setting with the shorter cutter was no problem.
        I don’t know how you are holding your cutters,  but if you are using an ER style collet,  then there’s no way shorter cutters can get anywhere near the table surface.
        Jim.
        #848296
        Steve Withnell
          @stevewithnell34426
          Hi Jim,
          That was my first thought,  I was using an engraving cutter in a collet chuck, so close to the Z limit,  even with a 6mm spoil board.   So I reset the whole thing around a 50mm thick spoil board and it made no difference.   The cutter path is now well within the machine limits and the problem continues.   It’s quite random, sometimes it won’t complete a character, then it will complete six.
          The status is ‘Limits STOP[Ext-Movement Info]’
          Just now,  the machine wouldn’t reset without multiple attempts and moving the axes manually would trigger it.   Now it’s been running for about 30 minutes without issue, so quite hard to diagnose,  I’ve been stood watching the diagnostics panel, but its hard watch without blinking for long periods 🙂  not seen even a flicker on the limit switch indicators.
          Steve
          #848306
          Keith Petley
            @keithpetley53472
            Hi Steve,
            I converted my KX1 to run Linuxcnc and in the process traced most of the electronics.
            The USB card is a Leafboy77 AKZ250, details still on their website here:
            https://leafboy77.com/?page_id=25/#downloads
            As well as the schematics the manual is quite useful as it gives explanations of the inputs and outputs.
            The following pictures are the pinouts as I traced them ( I couldn’t find a way to easily post a pdf ).
            Keith
            AX250-1
            AX250-2
            #848461
            Steve Withnell
              @stevewithnell34426
              Thanks Keith,  good stuff there.
              #848462
              Robert Atkinson 2
                @robertatkinson2
                Some things to check:
                Loose connection or connector affected by vibration
                Limit switch worn
                Electrical interference
                Can you run a couple of test cases, one with no cutter and the spindle turning and one with no cutter and the spindle not turning?
                The first to rule out vibration and the second to reduce possible electrical interference.
                Robert.
                #848469
                Keith Rogers 2
                  @keithrogers2
                  Hi Steve.
                  I’ve had similar problem with my mill in the past.
                  Easily cured by running the driver test that’s within Mach 3.
                  If you haven’t done that I suggest you try it, it may sort it out.
                  Keith.
                  #849052
                  Steve Withnell
                    @stevewithnell34426
                    Thanks,  I wasn’t aware of that.     It does seem to be only the engraving job that forces the issue.   I ran a two hour pocketing job on a chunk of H30 with a 6mm cutter and the mill never missed a beat.
                    I’ll run the driver test and see what that reveals.    I’ve also noticed there is no ferrite on the USB cable,  I have some chunky -31 toroids so I’ll add a couple of those into the set up just in case it’s a PC end issue.
