What did I buy ?
What did I buy ?
Home Forums Clocks and Scientific Instruments What did I buy ?
Viewing 25 posts - 1 through 25 (of 33 total)
  • #839318
      Picked this up cheaply …
      I will post more photos when I’ve removed some of the grime.
      … the shrivelled squeezy bottle has a label which may possibly give us a clue, but I don’t hold out much hope.
        The mighty Google tells me:
        IMG_1450
        #839323
        Robert Atkinson 2
          @robertatkinson2
          No photo visible here. Looks like the forum bug is still there.
          Robert.
          #839324
            Don’t understand what the forum has done to my post … Grrr!!
            The subject line included the words CASELLA, LONDON within angled brackets
            and there were two photos
            Maybe they will suddenly appear … or maybe not.
              Grindstone Cowboy
                @grindstonecowboy
                Anything between angled brackets has probably been interpreted as some form of HTML and disappeared into a forum black hole.
                Test – putting the words “black hole” between angled brackets here <black hole>
                Rob
                Edit – seems ok in the body of a post
                #839334
                  Nice try, Rob
                  Robert Atkinson 2
                    @robertatkinson2
                    Ahh an inclined manometer. Used to measure low pressure differentials. Many used special low density fluids often kerosine based.
                    Robert.
                    #839338
                      Thanks, Robert … I just need to find the instructions now
                      MichaelG
                      #839353
                        I soaked the label off the bottle, and have the text [with only the single most important word being illegible ! ]
                        Maybe tomorrow, in daylight
                        IMG_0389
                          … Which led me to this:
                          https://www.ebay.co.uk/itm/196750926471
                          … with lots of nice pictures and a fairly good description.
                          Wingo
                            @wingo
                            I think it’s a DP gauge normally used to check filter banks in building heating and venting systems.
                            High DP means time to change the filter. Some ‘roll’ type filters used a HP to trigger a motor to wind the filter onto a new section.
                            Michael
                            #839362
                            peak4
                              @peak4
                              There’s also a later one, but again without paperwork “Differential Manometer” might be a helpful search term, though I didn’t immediately spot anything obvious on how to use it, or what should be in the tube.
                              https://www.ebay.co.uk/itm/155631714555
                              Bill
                              #839365
                              Robert Atkinson 2
                                @robertatkinson2
                                #839366
                                peak4
                                  @peak4
                                  Page 95 of this one is getting close, suggesting yours is a little after the date of this catalogue
                                  https://www.analogweather.com/uploads/7/7/7/5/77750690/casella_-_meteorological_and_scientific_instrument_catalog_684_-_1948.pdf
                                  This was the main download page
                                  https://www.analogweather.com/-casella.html
                                  image_2026-02-25_223329195
                                  #839370
                                  Grindstone Cowboy
                                    @grindstonecowboy
                                    That says “FLUID”
                                    Rob
                                    #839380
                                      Well done, Rob !
                                      I’ve just woken-up, realising that it was the only word that could reasonably fit.
                                      … a cruel joke by Casella, methinks !
                                      Edit: from Bill’s reference, the bottle likely contained something from the photographic industry, or plain water with a drop of Fairy Liquid.
                                      #839383
                                      Alan Charleston
                                        @alancharleston78882
                                        Hi Michael,
                                        It’s an incline manometer. I used to use one to measure the pressure drop across a pitot tube when measuring the gas velocities during stack testing. It’s inclined because the pressures are small and the incline expands the scale so it’s easier to read.
                                        The liquid had a density of I think 0.86 which also lengthened the scale. The density needs to be correct for the scale reading to be accurate. When the first digital manometers first came out they were very expensive but I was keen to get one. I guess that tells you what I thought of the incline manometers.
                                        Alan C.
                                        #839402
                                          Thanks Alan … Yes, I understand the logic of the incline, but as you observe, knowing the density of the fluid would be critical if the measurements are to be meaningful.
                                          … or is it just used as a comparator ??
                                          Robert Atkinson 2
                                            @robertatkinson2
                                            The Manometer is an accurate differential pressure gauge but accuracy depends on the density of the fluid. We used to change the fluid in the ones in an aircraft instrument shop every year. Density can change due to evaporation of volatile components. Inclined manometers normally use low density fluids. Why increase sensitivity by inclining and then reduce it with a high density fluid? High or low is relative to water (1).
                                            The manometer can be calibrated directly in pressur (inches of water, PSI, millibar, whatever)  or if intended for velocity measurement or similar it may have custom calibration for a specific transducer like a pitot-static probe, venturi etc.
                                            Robert.
                                            #839427
                                              My point, Robert was that Bill’s quote explicitly references water with the addition of a wetting agent … whereas Alan recalls using a liquid with a density of about 0.86
                                              This innocent will remain bewildered until he reads the instruction manual for the instrument.
                                              Robert Atkinson 2
                                                @robertatkinson2
                                                It is unlikey that the unit was supplied with a bottle of “fluid” if it was intended for use with water.
                                                A manual almost https://ehive.com/collections/6274/objects/633426/instruction-leaflet-of-draught-guage
                                                Info but paywalled Journal of Scientific Instruments, Volume 29, Number 2
                                                Robert.
                                                #839502
                                                duncan webster 1
                                                  @duncanwebster1
                                                  If we knew the angle of the tube from horizontal, the distance between the markings, and what units they represent, the required fluid density would be fairly easy to calculate.
                                                  As the angle to horizontal is important I’m surprised it doesn’t have a bubble level incorporated.
                                                  #839503
                                                    Thanks, Robert … I now have the paywalled item, courtesy of “institutional access”
                                                    [which regrettably means I am not permitted to distribute it]
                                                    Suffice it to say that yes …
                                                    The indicating medium is a special clear, non-staining, mobile liquid of specific gravity less than unity […]
                                                    Sounds to me like Casella was selling ‘Snake Oil’
                                                    Edit: … The article is however also available here:
                                                    https://iopscience.iop.org/article/10.1088/0950-7671/29/2/415/pdf
                                                    No paywall, no need for me to worry about sharing 🙂
                                                    #839504
                                                      It does
                                                      Michael G
