Mike may struggle with his 3-pronged requirement, which has the 2 out 3 gotcha:
- no-one cheap and safe will do the move
- chaps prepared to do the move cheaply aren’t safe
- chaps who can do the move safely aren’t cheap
So moving machines can be expensive.
I’d be inclined to use an ordinary carrier. If you attach the mill securely to a pallet, and wrap well, they’ll shift it. Howard is right to be nervous because machine tools are top-heavy, liable to fall over, and slip in slings etc. Shouldn’t happen if the machine is properly attached to a pallet, because they’re only lifted a few inches above floor level from the bottom. Carriers shift gazillions of heavy objects on pallets without incident. There is a risk, because the driver might be caught out by an unbalanced load. Mike could reduce the risk by securing his mill to a full-size pallet, but that puts the price up. As does insurance: the cheapest move rate probably doesn’t cover the full value of the machine.
Cheapest option is DIY, provided you have suitable friends prepared to help for peanuts. But beware, inexperienced chums working with ramps, crowbars and a van or trailer are far less safe than a professional with a lorry, tail-lift, and pallet truck. Now I’m retired, none of my friends are suitable. Nor are my families young males.
Landylift may have stopped entirely. Used to work UK-wide, then only Yorkshire-local, and recent homeworkshop posts report he’s not answering the phone. Worth trying though – very good reputation if he’s available. I don’t know of anyone else.
