Old Mart –
I like that technique for making and fitting bearing liners, but here I am making a clamp so need an appreciable joint gap so the liners will close down on the bar.
You could hold the halves together for soldering by twisting wire round them; by an old, so sacrificeable, worm–drive clip; by brass screws just outside what will become the liners; or by simple G-clamps made from a bit of channel or bent steel strip and an ordinary set-screw. (I think that was LBSC’s way!)
Dave –
Good point I’d not really thought when I started. I gave the second sleeve a small lip to stop it sliding in one direction at least, but had envisaged perhaps a couple of simple dowels / roll-pins / screws to act as retainers.
Then realised I could use two 1/4″-BSW tapped holes already in the casting. I drilled the still-cylindrical sleeves with the tapping size (5.1mm) then turned little tails on two set-screws to engage with that hole. Only after dividing the shells into two, realised this placed the cut obliquely to the clamping.
Then……
I hit the problem that one split shell fitted, sort of, the other didn’t.
So I spent this afternoon experimenting.
I had already used one of the original sleeves, by halving that lengthways.
I adopted, I think, if I understand them correctly, Diogenes’ and Andrew’s suggestion of slots along the remaining original sleeve. Using the slitting-saw, and rotating the sleeve by eye from position to position in a T-slot as “Vee-block”, I cut very thin slots almost through the wall.
Oh, and the “Haunted Workshop” ghosts then added their bit by hiding one half of the split, faulty sleeve!
So eventually I finished with a reasonably satisfactory compromise. One of the new two-part sleeves in the front eye, the original sleeve for the rear eye, with thin axial grooves to make it flexible.
The photos show what’s what:
The Denbigh H4 Horizontal Mill, for line-shaft drive, with its non-original, 2″ diameter over-arm and the makeshift sleeves that came with it; and the (broken!) even more makeshift, drop-bracket on an eccentric spigot to allow its alignment with the spindle.
Note the two link-belts. Many owners of similar machines put the modern drive motor and pulleys out to one side, so as to use continuous belts. This works well but is very ungainly and steals a sizeable volume of workshop.
I want the drive above this machine, neater and more compact in a very cramped shed. That DRO unit in the background is on a Myford VMC mill, and side-mounting the Denbigh’s drive to the right could obstruct easy access to the Myford, but to the left, to an adjacent bench-drill! Yet going too high above could obstruct the travelling-hoist’s journeys.
That is the next part of the project, and thankyou Diogenes for that worm-drive unit, offering a spindle speed of around 75rpm (1350 motor / 18:1 worm-gear), depending on the intermediate pulley. I can live with a single speed, especially if I restore the table-feed drive.
And without the fittings. The 2.5″ dia apertures as machined by the Staffordshire company. The “Cyclop’s Eye” in my Haunted Workshop piece. It was making the new sleeves for this, that had created the eerie sounds. This picture shows why I am very wary of either an excessively tight fit, or of having to pull the clamps-nuts down too tightly. That little bulge just visible beyond the eye is a puzzle. It is a protrusion holding only a vertical blind hole about 5/16″ dia, and perhaps originally was to hold a lamp.
The sleeves:
Left: one of the previous owner’s efforts, fully halved by me.
Centre: one half of my replacements showing the half-hole that engages the locating-screw. It was one of these sleeves that had “Shrunk” (curled inwards).
Right: the other sleeve as it came with the machine, with one saw-cut right through; and now with five sawn slots along the outer wall, opposite the through-slot.
