AJ Reeves 5 inch driving trolley bogies
Home › Forums › Locomotives › AJ Reeves 5 inch driving trolley bogies
  • #852331
    Ian R
      @ianr
      I have an AJ Reeves 5 inch driving trolley. I have noticed that that the rubbing metal blocks between the upper and lower section of the bogey have worn away and no longer stop tilt from side to side when cornering.
      I am looking for plans or specification of these blocks so I can replace them.
      They do not seem to be identified on the drawings on AJ Reeves web site
      #852338
      paul rushmer
        @paulrushmer83015
        If my memory is correct they should be loose rollers! I will try to look out the drawings later.
        Paul
        #852342
        Ian R
          @ianr
          Paul
          These are solid brass oval blocks with screw in middle about 1 1/2 inch by 3/4 inch
          #852352
          Bazyle
            @bazyle
            Photos? There may be more than one design. I agree the ones I know had a groove for bearings.
            #852356
            Ian R
              @ianr
              Bazyle
              No groove for bearings a solid strip of metal
              Photos to follow
              #852358
              paul rushmer
                @paulrushmer83015
                Just looked at my drawings top bogie bolster has 1/2 by 1 1/4 pockets 7/32 deep with two 1/4 dia rollers 7/16 long in each pocket. The centre pin has a 1/4 thick brass rubbing plate. Hope this helps Paul
                #852443
                Ian R
                  @ianr
                  Paul
                  Thank you for looking at drawings. Unless mine have been modified they only have a solid oval block and the centre pin a brass rubbing plate
                  No Rollers
                Home › Forums › Locomotives › Topics
