Opposed Piston Engines
Home › Forums › The Tea Room › Opposed Piston Engines
Viewing 25 posts - 1 through 25 (of 30 total)
  • #812772
    Richard Simpson
      @richardsimpson88330
      Just a Sunday morning musing as I have a browse through some of the beautiful projects there are on display here.  Having had experience in my sea going career of what are referred to as opposed piston internal combustion engines, I have frequently thought of such an engine configuration to be at the pinnacle of reciprocating engine design as regards power to weight ratio.  This is, of course, precisely why they were developed into the ‘Deltic’ configuration, which went on to power diesel locomotives and fast navy craft of the post war period.
      Obviously the downside of the configuration is that it can only be used in a 2 stroke cycle engine, as there is nowhere to put the normally required valves for a 4 stroke engine, rendering them not popular with the drive towards fuel efficiency, but I’ve often wondered whether an opposed piston arrangement could have ever been used as a steam engine.  So my question is whether anyone has ever come across a model of such an engine, either as a design or a finished item?  I cannot see any reason why it would not work with steam as steam inlet and outlet is simply controlled by ports, pretty much in the same way as a 2 stroke internal combustion engine works.
      #812780
      Robert Atkinson 2
        @robertatkinson2
        How about using a sleeve valve with opposed pistons?
        Robert.
        #812783
        Richard Simpson
          I don’t see why that couldn’t be done with opposed pistons.  I’m really just wondering if there has ever been a model of an opposed piston engine.
          For anyone not familiar with the arrangement look up ‘Doxford Marine Engines’ and have a look at this display piece in the Science Museum.  Double click to enlarge, well worth it:
          #812788
          cogdobbler
            @cogdobbler
            I have seen pictures of an opposed piston Stirling  engine model. The displacer pistons were opposed, with the flame in the middle of the horizontal displacer cylinder and the two finned “cold ends” at each end of the one cylinder. I can’t for the life of me remember it’s name or find it online. I rather think it was perhaps a commercial kit a the cylinder fins looked cast, from what I remember.
            Never seen an opposed steamer though. Could be an interesting project , especially if you used rocking beams to connect two conrods to the same crankshaft as some early engines did. Might be a very wide engine with the crossheads at each end.
            #812789
            Richard Simpson
              Ah, found a couple of combustion engines, so they exist:
              Can’t find a steam engine though.
              #812790
              cogdobbler
                @cogdobbler
                <p style=”text-align: left;”>Some lovely workmanship there. And two very unusual engines.</p>
                #812792
                Colin Bishop
                  @colinbishop34627
                  Is this the sort of thing you mean Richard?
                  DIY Assembly Steam Engine Kit Model Science Experiment with Electric Generator
                  Some other interesting engines on the website.
                  Colin
                  #812797
                    Richard Simpson
                      Hi Colin, Many thanks for that, however that is an opposed cylinder engine and not an opposed piston engine.  An opposed cylinder engine, such as a lot of Porsche engines, Volkswagen Beetles and BMW motorcycles have cylinders, each with its own piston, on either side of a common crankshaft.  Frequently referred to as a ‘Flat Four’, ‘Flat Six’ or ‘Flat Twin’ etc.  An opposed piston engine has two pistons in one cylinder, which move in opposing directions.  Both pistons are connected to a single crankshaft, either by gearing or by different con rods.
                      #812809
                      Richard Simpson
                        Dave, What an interesting read Ericsson proved to be.  Quite a few innovative ideas that become accepted throughout the 19th Century.  And by the look of it possibly the first ever sea going Marine Engineer.
                        The Deltic engine was an absolutely stunning piece of engineering design, just studying a cross sectional drawing can only make anyone marvel at how the concept was even created.
                        #812810
                          One of our members is currently building an opposed piston IC engine.
                          I can’t see why it would not work for steam. Really it just needs to be two Uniflow or single acting cylinders sharing a common “head”. As they would be single acting you could get away with just conrods and no need for crosheads and their associated guides
                          One of Elmers many enginedesigns is a simple opposed piston engine, I’ve got the drawings knocking about
                          Variations on the theme are IC engines like the popular Mery casting kit which has a central piston and combustion chambers at either end
                          #812811
                          Richard Simpson
                            I guess that would effectively be considered a ‘Double Acting’ internal combustion engine.
                            #812812
                            Robert Atkinson 2
                              @robertatkinson2
                              The USS Monitor engine was opposed pistons but in two cylinders. I’s been modelled:
                              https://modelengineeringwebsite.com/USS_Monitor_engine.html
                              That might make a starting point.
                              #812816
                              Colin Bishop
                                @colinbishop34627
                                Thanks for the correction Richard, I’ll never make an engineer but I do find watching these devices in action and their ingenuity fascinating. A few years back there was a chap at the Brighton show with a collection of Stirling engines in different variations which he was demonstrating.
                                Colin
                                #812818
                                David Jupp
                                  @davidjupp51506
                                  A ‘closer to prototype’ model of the USS Monitor engine can be seen at
                                  http://www.stationarysteam.com/stationarysteam_003.htm
                                  Unfortunately the full set of drawings mentioned on the site no longer seems to be available for download.
                                  #812819
                                  cogdobbler
                                    @cogdobbler
                                    <p style=”text-align: left;”>I found the model opposed Stirling engine I mentioned earlier. It’s called the Essex. Castings by Myfordboy apparently.</p>
                                    essex
                                    #812826
                                    Richard Simpson
                                      Some beautiful engines there gents.  Thanks for the links.
                                      #812827
                                        This is quite a nice model, I think it is one piston but with opposing rods. been a while since I saw it in the flesh.
                                        20181124_103045
                                        20181124_124222
                                        #812833
                                        Roger B
                                          @rogerb61624
                                          I am building a 20mm bore 2 stroke diesel based on the Junkers CLM engines that were used in transport as well as stationary applications. There are some pictures on my Flickr and You Tube accounts:
                                          Junkers Inlet Piston | Roger Bryant | Flickr
                                          youtube.com/shorts/sL9x0OvkPTY?feature=share
                                          The full build log is on MEM.
                                          #812855
                                          Richard Simpson
                                            Jason,  Trying to put the bits and pieces together from the pictures.  Obviously two throws on the crankshaft connected via the shaft to two piston rods in either end of the cylinder.
                                            It does look like though the large arms on the shaft connected to the crankshaft via the con rods are both angled inwards.  It does look however that the two piston rods are both in different positions, one being all the way in and the other being all the way out.  This would tend to indicate that, if there are two pistons they are not working in opposition.  Maybe the rods are both connected to either side of the same piston.  Or maybe one piston is the working piston and there could be another opening and closing ports.  Although there does appear to be a valve chest so I can’t say.
                                            #812867
                                            Wade Beatty
                                              @wadebeatty78296
                                              I was engineer on a tugboat many years ago that had 2 Fairbanks Morse 38 8-1/8 opposed piston engines. They were used on diesel locomotives and submarines also. The upper and lower crankshaft were connected by a vertical angle gear drive on the front of the engine. To change a top piston you could either disconnect all the top connecting rods and pull the top crankshaft or remove the lower piston and pull the top piston down into the crankcase. A painfull process as I remember. You might look at drawings for inspiration.
                                              #812874
                                              derek hall 1
                                                @derekhall1
                                                #812880
                                                  I remembered that Elmer has another opposed piston steam engine, his #34.
                                                  This is actually a twin cylinder horozontal with each cylinder having a pair of pistons and a rotary valve feeding and exhausting at the middle of the cylinder. One piston is on a solid rod and the other a hollow one so all the linkages are at one end of the engine. I’ve seen a few builds of this one but not the best layout for marine use unless it’s a paddle steamer..
                                                  opposed 34
                                                  #812895
                                                  Richard Simpson
                                                    #812903
                                                      Seems worth posting the link to some photos of the Doxford works again.
