Replacement gear
Replacement gear
Home › Forums › Manual machine tools › Replacement gear
  • #800620
    David George 1
      @davidgeorge1
      A friend has been given a Chester machine tools, Conquest Mill Super.  has anyone any information on this mill as I believe it is discontinued and the original gear for the spindle drive is a plastic but smashed gear. I could make one but if anyone could help with a replacement I would be most grateful. I wondered if this mill could have been used by other retailers with a different badge on as there is no handbook with this mill so no part numbers etc.
      David George
      #800633
      Hugh Stewart-Smith 1
        @hughstewart-smith1
        hello David,
        if you friend could send a photo of the gear in question, we might be able to help.
        Hugh        Amadeal Ltd
        #800644
        John Haine
          @johnhaine32865
          It looks like a version of the generic “X2” mill so should be spares around.  Alternatively I think there are belt drive kits which make it more robust and quieter.
          #800648
          DC31k
            @dc31k
            There have been discussions of this issue in the past. Finding those threads and spending five seconds looking at them would tell you if the machine is the same as your own or not. Even if the machine is not identical, the solution used might bive you ideas.
            Including a picture of the machine would assist.
            #800684
            Stuart Smith 5
              @stuartsmith5
              Have you tried contacting Chester?
              They list 2 gears for the ‘Conquest super mill’ as spare parts.
              Link below:
              https://www.chesterhobbystore.com/shop/tooling-accessories/spare-parts/gears/
              They have a manual as well, if it is the same machine:
              https://www.chesterhobbystore.com/wp-content/uploads/2021/09/Conquest-Super-Mill-Operation-Manual.pdf?srsltid=AfmBOor9KrBQUk2XEX7mTvPHHNjST9jmq_Aw_OohB61I5Rd0BsOSiD8v
              Stuart
              #800745
              David George 1
                @davidgeorge1
                These are the pictures of the gears I have not got any other information yet and the part numbers are not in the parts list in the handbook. He has talked to Chester but without more information he is stuck. I think I will have to ask him to send them to me to check sizes and tooth count etc.
                IMG-20250527-WA0003
                IMG-20250527-WA0001
                IMG-20250527-WA0000
                David
                #800757
                Speedy Builder5
                  @speedybuilder5
                  In case friend can’t find a replacement, could this sort of thing help
                  Free STL Gear designer   https://www.stlgears.com/
                  Bob
                  #800764
                  Stuart Smith 5
                    @stuartsmith5
                    This looks like the one you want:
                    C3D42210-10AB-438E-B119-737D6AA42E50
                    Stuart
                    #800766
                    John Hinkley
                      @johnhinkley26699
                      I can’t see the gear to which Stuart has linked, but this one from Amadeal looks very similar to the broken one that David has shown.  As far as I can estimate, the gear tooth counts are the same and these gears were common to a lot of mills and mini lathes produced around the same time, designed apparently to destroy themselves when stressed to protect the rest of the transmission.
                        ARC do a 12/20 in metal as well as the original plastic, just check the bores are the same if you want to go for spmething stronger.
                        #801016
                        David George 1
                          @davidgeorge1
                          Thanks for all the help. Chester Machine tools have come up with a new replacement pair. He bought them over this morning for me to check them and  luckily he did as the main gear shaft was over size by 0,025 and he was going to press it on and would possibly split the plastic gear. After a scrape and pollish on the inside  of the gear it was a tight push fit.
                          David
                          #801194
                          old mart
                            @oldmart
                            At that price, it would be a good idea to get a spare. The nylon will run quieter and act as a safety link in the event of a crash.
