Screw Supplies
Screw Supplies
Home Forums Beginners questions Screw Supplies
  • #7811
    David Hill 5
      @davidhill5
      #205256
      David Hill 5
        @davidhill5
        I am quite new to model engineering and am following drawings that specify an M8 socket cap screw with 0.75 pitch. I made the mistake of buying, at great cost, the taps (and a die too) before I bought the screws. I now cannot find any supplier of the screws! I have tried the usual suppliers and even Emkay cannot help me. Can anyone suggest a supplier that maybe I haven't tried?
        Thanks in advance,
        David
        #205258
          I suppose as you have the die you could buy a long M8 cap screw that has a portion of plain shank and thread that to the finer pitch.
          Out of interest whats the engine?
          #205261
          V8Eng
            @v8eng
            You could try here.
            David Hill 5
              @davidhill5
              Thanks guys, have sent off an email to E C Pitcher, hope they can help. I had thought about cutting the thread from a blank part of a coarser thread but was seeking an easier way!
              The engine is actually a steam launch engine. It is a Taylor Twin of 2.5" bore so not sure it comes under the "model" engineering label. The very fine thread is needed for the main split bearings.
              David
              #205267
                They are probably sold as spare parts for some form of engine big ends so hard to find when just looking for screws but easy if you have a part number. You quite often find the fine and extra fine pitches used for this sort of thing.
                #205270
                Lambton
                  @lambton
                  I wonder if the designer of the engine ever found any M8 x 0.75 cap screws?
                  I was always taught to check the availability of commercially made fasteners and components before finalising any design. On the odd occasion where difficult components were essential, ensure I had found a supplier prepared to make them at an affordable price. These points are not always appreciated by customers, arty designers or inventors.
                  Just because there is an ISO standard for a particular fastener, in this case M8 x 0.75, it does not mean that any components are manufactured to it unless there is sufficient general demand. The same applies to BS and other specifications for steel, aluminium etc.
                  #205272
                    Have you tried asking on the Steamboating forum engine section.
                    Cap heads seem a bit odd for split bearings, I would have though studs with nuts & locknuts so you can adjust the bearings?
                    Was it an imperial design that has been converted to metric?
                    #205273
                      David,
                      It looks like some bicycles use that extra-fine thread.
                      See here
                      Also … Aerospace fasteners, here smile p
                      Edited By Michael Gilligan on 22/09/2015 10:41:40
                      #205277
                      Anonymous
                        Since you have the taps and die it should be trivial to make the required bolts, or studs and nuts. Alternatively change to a different thread; 5/16" BSF for instance?
                        #205283
                        David Hill 5
                          @davidhill5
                          Thanks to all for your words of wisdom all of which is taken onboard. To answer JasonB, yes, the drawings have been converted to metric and I am in the SBA. I think that I will instead use studs with nuts, all of which I can make myself. Thanks for all your inputs.
                          David
                          #205367
                          peak4
                            @peak4
                            Just off to the pub, so a very brief reply;
                            Any good?
                              Posted by bill williams 3 on 22/09/2015 22:16:18:
                              Any good?
                              Whoo Hoo … deja vu
                              peak4
                                @peak4
                                Posted by Michael Gilligan on 22/09/2015 23:20:07:
                                Any good?
                                Whoo Hoo … deja vu
                                Ah, knew I should have waited until I had more time to read everything properly; so much for posting in a rush blush
                                I'd check out motorcycle dealers too, though that was probably mentioned earlier as well.
