Posted by wavering on 15/08/2012 15:29:10:
I have a Harrison lathe which has defintely got a bus pass and probably a free TV licence too
No matter how carefully I turn things it looks like rats have been gnawing at it. As far as I can see there are 3 possible explanations
1. I don't know what I am doing
2. The tools are blunt
3. The lathe is knackered
Or all three
Any suggestions as to the best way forward?
Bob
The age shouldn't be a problem I started with a lathe about 100 years old. If it's knackered you can fix it/get round it.
Your numbered points:
1. Fixed by asking here.
2. Try rubbing the cutting edge across the back of your fingernail. If it won't produce fine shavings sharpen it.
3. Make sure there isn't any play in the headstock bearings they should be tight enough so that without the drive connected if you spin the chuck by hand it won't do more than one or two revolutions before stopping. Make sure the gibs are tight enough. Is there any possibility of the tool movine in the toolpost or vibrating? Keep the tool tip as close to the toolpost as you can. Does the lathe vibrate much when in drive?
Hope that gives you something to look at as a start.
Russell.
