ARROW spring assisted shaper
Home Forums Beginners questions ARROW spring assisted shaper
  • #6129
    Ady1
      @ady1
      #90198
      Ady1
        @ady1
        I found this on Tonys site and thought "that could be useful!"
        The spring "absorbs 50% of labour required by the operator" which must mean that a powered machine doing a job could do the same job with 50% less motor power kinda thing
        Now while 50% is a bit of a stretch(a lot of a stretch) I would be intruiged to know if their system did actually generate any improvements
        Does anyone know how their system worked?
        Presumably the gain on the forward stroke was countered by the reversing stroke being harder
        Anyone ever used one of these spring assisted units?
        http://www.lathes.co.uk/arrowshaper/
        Edited By Ady1 on 04/05/2012 10:58:51
        #90201
        John McNamara
          @johnmcnamara74883
          My guess is the spring is compressed on the return stroke at a moderate pressure. Then on the power stroke the built up pressure is added to the force of the cut. It makes some sense. However the total work performed must be the same. After almost 400 years (B 1642); In the real non sub atomic world Sir Isaac Newton still reigns supreme. Energy must be conserved.
          John M
          #90207
          Nobby
            @nobby
            Hi Andi1
            I wonder if i could add this to my Drummond shaper ?drummond shaper
            #90226
            colin hawes
              @colinhawes85982
              When I use my shaper I often need to stop the ram on a part of it's travel.The idea of having so much energy stored in a powerful spring seems very dangerous. Be careful! Colin
              #90242
              Nobby
                @nobby
                HI Colin & Guys
                On a 36" shaper as colin said to remove metal on a central area of a job I used to shape between 2 slots . My drummond is great for slotting key slots in 5/8" Dia bores. IE gears and collars. I know I should not slappedd wrist Fit a grinding head for light surface grinding . I know it's not a J&S 540
                Nobby
                #90262
                joegib
                  @joegib
                  He, he, you forgot to add a smiley.
                  Turn that machine through 90 degrees and you've got a unit whose operation is essentially the same as a pillar drill with the ram being returned to the start position in the same way as a drill spindle is by its coil spring. A spring is a energy store and it can only output the energy that has first been put into it by you (or a motor). In other words it acquires potential energy (from you) on compression and returns it on release.
                  As an energy saver its about as much use as recommending that people in an elevated position exploit their potential energy by falling down stairs rather than making a controlled descent.laugh
                  Joe
                  #90290
                  John McNamara
                    @johnmcnamara74883
                    Hi All I have repeated the obscured by advertising text from my first post
                    "My guess is the spring is compressed on the return stroke at a moderate pressure. Then on the power stroke the built up pressure is added to the force of the cut. It makes some sense. However the total work performed must be the same. After almost 400 years (B 1642); In the real non sub atomic world Sir Isaac Newton still reigns supreme. Energy must be conserved."
                    For a human powered machine using a lever it makes some sense to use a spring; It allows a greater force than one person could apply to be added to the power stroke. As long as the lever is returned to the start position (The spring is at its uncompressed state or limit if it is preloaded), before the handle is released there is no risk of the potential spring energy being released suddenly.
                    I guess the greatest risk is that the ram is stopped say due to too greater cut being put on, after which the operator then moved his hands to the work to make an adjustment to the work and the ram suddenly moved propelled by the spring there could be serious injury.
                    I guess you cannot protect some of the people all of the time.
                    Cheers
                    Ady1
                      @ady1
                      My own guess would be that the backstroke would store some energy, so would be 50% harder to do.
                      So, in a perfect world, a 0.5HP motor could do the work of a 1HP motor, but it would do twice as much work so you would get the electric bill of a 1HP motor
                      The motor would compress the spring on the return stroke doing 0.5HP of work
                      The motor would then begin the cutting stroke doing 0.5HP of work, assisted by the spring which would be contributing 0.5HP of work, giving you 1HP of cutting power
                      All reduced by the vagaries of the real world but hopefully giving you at least an extra 50% of cutting power, so 0.75HP with a 0.5HP motor
                      The spring design would be important, you would want the energy to reach 0.0HP AFTER the end of the cutting stroke, and begin compression to full power on the return stroke.
                      An air compression system may also work, like when you put your thumb on a bike pump and compress the air inside, anything which stores energy could be used.
                      The best system would be one which creates a constant release of energy across the entire cutting stroke, the above compression storage systems start at a peak and reduce with the distance cut
                      2cents
                      On a powered shaper the shaper gearing system would prevent this surge
                      It would definitely be a risk with a hand shaper though, but you don't ever put your fingers near a tool problem, on a shaper a jam is relieved at the top of the ram by winding back the clapper slide, darwinism would soon teach you to keep one hand on the shaper handle(the human is the gearing system with a hand powered shaper) while the other hand screws back the cutting tool depth.
                      I recall reading somewhere that a shaper is one of the only power tools which has an operators hand constantly on a moving part it while it works
                      Edited By Ady1 on 06/05/2012 09:15:42
                      #90297
                      Ady1
                        @ady1
                        An air compression system would also be safer for tool jams
                        Tool jams
                        Stop machine
                        open air pressure valve
                        Adjust tool to relieve jam
                        close air pressure valve
                        restart machine
                        #90328
                        colin hawes
                          @colinhawes85982
                          Not everyone has the strength of a horse so,for a hand shaper, a longer handle should give the best results if more power is needed. Simples. Colin
                          #90332
                          Nobby
                            @nobby
                            Hi Colin
                            Thats a good idea . I will try that tomorrow a peice of tubing springs to mind . I love mine for small fine jobs. In industry they are not used know now high flow milling and cnc finisded them off.
                            Regards Nobby
