Southbend shaper modeles of 1/8
Home › Forums › Miscellaneous models › Southbend shaper modeles of 1/8
  • #523107
    Richard Hudson 4
      @richardhudson4
      67699aa7-969a-4509-8df3-fadfd8b0d281.jpeg681758d6-8971-4c04-a854-85c2830fab8e.jpegi recently made a model of my southbend 9 inch shaper. I stripped my shaper down and measured all the parts involved , worked out a scale which I think was 1/5 and got to work. The model was made without using any castings a was made mainly from pieces of 1/8 “ plate welded together and scrap metal machined up to suit.67699aa7-969a-4509-8df3-fadfd8b0d281.jpeg
      #4334
      Richard Hudson 4
        @richardhudson4
        #523110
        Brian H
          @brianh50089
          Very nice, how did you machine the 'T' slots? The traction engine looks good too, Can you give us the details?
          Brian
          #523112
          Richard Hudson 4
            @richardhudson4
            e4f0d197-aa67-4e2e-9392-937186c4538a.jpeg9af39b77-1708-4cdb-9473-13dd00f4b302.jpeg025c604b-4a5b-488a-b14c-7852c3e60045.jpegHi Brian I machined the tee slots using a modified 5 mm end mill. I milled a ordinary slot first and the used an end mill that I necked with a Dremel grinder to only cut on the end and give the tee shape.
            The engine is my Durham and North Yorkshire in 2 inch scale and is a work in progress
            #523117
            Jeff Dayman
              @jeffdayman43397
              shaper and TE look great!
              #523170
              Ady1
                @ady1
                lovely
                #523174
                Nigel Graham 2
                  @nigelgraham2
                  Fine work! Thank you for showing us.
                  I must admit I'd not thought to make a T-slot cutter in that way, but come to think of it, I'm pretty sure there's one among my cutters-from-goodness-knows-where.
                  We look forwards to progress on the engine.
                Home › Forums › Miscellaneous models › Topics
