Copper Pipe Chess Set Completion help
Home Forums Help and Assistance! (Offered or Wanted) Copper Pipe Chess Set Completion help
  • #268371
    Derek Hart 1
      @derekhart1
      I write in the hope of enlisting your support in identifying anyone within your modelling clubs who may be able to help me in the making of two small chess pieces fashioned from copper piping.
      The background story to this perhaps unusual request was that some 50 years ago whilst attending evening classes my wife set about making a Chess set from what was then imperial ¾” copper pipe.
      Regrettably, the full set was never completed despite her best endeavours and two pieces were never made. These pieces were the Pawn and the King and the photos enclosed show how they should look.
      The approximate height of the pieces is:-
      The Pawn is 35mm overall in height and the King is 72mm in height.
      The purpose of this exercise is to try to complete the set by no later than end of Feb 2017, which will be in time for our Golden Wedding anniversary but some additional work will be required once the two missing pieces are completed.
      Once the two pieces are made some, further work will be required such as weighting the pieces in order to get the feel right and some plating work in order to identify the two sets.
      I fully understand that imperial size pipe is no longer available and that the two pieces will have to be made from the current metric equivalent but that is not a problem.
      I enclose pictures of the two pieces to show how they look and would be happy to provide the existing Pawn and King should that be requested
      Please let me know what you think once you have had chance to consider the task in hand
      Many thanks and Best Regards
      Derek Hart
      Edited By Diane Carney on 25/11/2016 17:04:52
      #32842
      Derek Hart 1
        @derekhart1
        #268399
          The pictures will be good.
          3/4" copper pipe was a little thicker than present day but of slightly different OD. There is plenty of second hand pipework still being replaced. I expect I have a few short lengths around, if they can be found.
          This iz two number, one of each piece? There being multiple 'prawns' and it is not entirely clear if you need multiples, or one singular item of each.
          #268422
          Brian Oldford
            @brianoldford70365
            Where's the pictures please.
            #268428
              I've uploaded some pictures Derek sent me. It looks like his wife did some neat handiwork sorry some are rotated. I guess brass or stainless steel plugs in the base could provide the required weight. One set could be polished and laquered, the other blacked and laquered?
              #268476
              Ian S C
                @iansc
                Epoxy mixed with filings, maybe copper would be good, or a plug of lead epoxyed in would do for weighing the pieces.
                Ian S C
                #268481
                Nicholas Farr
                  @nicholasfarr14254
                  HI Derek, I have an old piece of 3/4" copper pipe which I removed from a disused water tank in my attic a couple of weeks ago, it has a usable length of at least 130mm. PM me an address and I will post it to you if you would like to have it.
                  Regards Nick.
                  #268492
                  steve de24
                    @stevede2433577
                    Nice looking chess pieces – any chance of uploading pics of all of the different pieces?
                    Anyone know a simple way to create the textured effect on the body?
                    Steve
                    #268497
                      Small cold chisel would soon put the textured pattern onto the pipe, slip it over a bar to stop it denting and tap away.
                      #268646
                      Derek Hart 1
                        @derekhart1
                        I am hopeful that somebody is able to make these two pieces for me as I have no workshop facilities.
                        Happy to discuss either by email of phone.
                        I am try to avoid my wife from discovering my cunning little plan at this stagewink
                        07879 430 515 if you can help
                        Best Regards
                        Derek
