Left hand Cobalt drill
Home Forums General Questions Left hand Cobalt drill
  • #531885
    Raphael Golez
      @raphaelgolez
      Hello to all,
      I was pulling out the pulley from my S7 motor which you guys have given a very good advice and it was fixed.
      Initially the pulley got stuck as I remember I placed a thread locker years ago as it keeps on unscrewing and I got fed up.
      This time I could not unscrew it and stip the head of the grub screw. I could not drill it as I believe its a hardened (unbrako??) screw. I managed to get the pulley out by using a puller but the broken grub screw remained. I tied heating it with a small butane torch to melt away the thread locker but nothing happened.
      As I read hear, one solution is to use a left hand drill to extract it out. I have been looking for a left hand cobalt drill but all I get is from ebay and i'm not to confident of the quality. I check on Arc-eurotrade and the reputable seller but all I can see are right hand cobalt drill. I don't want to drill trough it. Any thoughts or advice guys?
      Thanks,
      Raphael
      Edited By Raphael Golez on 05/03/2021 15:20:35
      #28028
      Raphael Golez
        @raphaelgolez
        #531887
        Anonymous
          Go to Drill Service – more types of drill than you can shake a stick at:
          Left Hand Drills
          #531888
          Tony Pratt 1
            @tonypratt1
            For this application an ordinary drill will be ok, it will either spin the grub screw into the pulley bore or just drill the screw out. From memory the grub screw is shorter than the bore diameter?
            Tony
            #531892
            Raphael Golez
              @raphaelgolez
              Thanks Andrew.
              Tony tried to screw into the bore but i think the thread lock is the culprit. I will try to heat it again with the butane torch. I will also get a left hand cobalt drill.
              Raphael
              #531901
              Jeff Dayman
                @jeffdayman43397
                After heating the setscrew and surrounding metal, hitting a small punch in the hex socket of the screw with a hammer, sharply, will often help get stuck screws moving.
                #531920
                noel shelley
                  @noelshelley55608
                  Grind a metric hex key that is just to big to a slight taper and tap it into the spoilt hex and try to unscrew, ideally whilst hot. Good Luck Noel.
                  #531927
                  Pete.
                    @pete-2
                    Andrew, how much is their postage, and do their prices include vat?
                    They require an account to access this information, unless I missed something, which is entirely possible.
                    #531953
                      Pete,
                      From their website: If you have not registered to buy on line please do and carriage is free on orders over £10nett
                      #531956
                      Pete.
                        @pete-2
                        Thanks, that's pretty reasonable then, do you know if the worm pattern stub drills would be suitable for drilling out a grub screw, they're noticeably cheaper than the other HsCo drills, if they are I might buy a few sizes as I don't think I have any left hand drill bits.
