Tufnol, Phenolic, SRBP, HPL, CGL, SGL
Home Forums General Questions Tufnol, Phenolic, SRBP, HPL, CGL, SGL
  • #27973
    Hollowpoint
      @hollowpoint
      #527148
      Hollowpoint
        @hollowpoint
        Guys I'm looking for some hard sheet material for use under a small lathe, I remembered back to some very hard plastics used in lab work surfaces and counter tops back in my school days which would be ideal.
        Searching around the web it seems to come under many different names, HPL, CGL, SGL, SRBP, and Phenolic resin to name but a few.
        I only need a small piece and was wondering if anyone knew of a supplier?
        Failing that, does anyone know of an alternative? It needs to be tuff and hard wearing for my application. Tufnol might have been an option had it not been only available in brown.
        Any suggestions?
        #527152
        Andy_G
          @andy_g
          Lab worktops are often made of ‘Trespa’ – a trade name for some type of laminate. It’s horrendously expensive, but you may be able to buy an off cut. (It cuts & machines OK with TCT woodworking tools.)
          #527156
          noel shelley
            @noelshelley55608
            The thing that comes to mind is what I would know as formica. Noel.
            #527158
            Hollowpoint
              @hollowpoint
              Posted by Andy_G on 14/02/2021 14:03:55:
              Yes,thats the stuff. And yes expensive! I was hoping someone knew where to get an offcut.
              #527177
              Jeff Dayman
                @jeffdayman43397
                Steel sheet galvanised, plated or painted would be cheaper, have much longer life, and be much more robust than laminates etc. as well as being the traditional proven under-lathe material. However if you really want laminate/plastic I would give a +1 to Noel's suggestion of formica, as used in kitchen counters. A kitchen or bath fitter shop may have an offcut or a counter that was cut too short for less than all new custom cut material.
                #527187
                Bo’sun
                  @bosun58570
                  Hello Hollowpoint,
                  What about the material used for the base of small trailers (Ifor Williams, etc). It's a phenolic covered plywood. Unfortunately, I haven't got a clue what it's called.
                  #527198
                  Roderick Jenkins
                    @roderickjenkins93242
                    Posted by Bo'sun on 14/02/2021 15:07:51:
                    Hello Hollowpoint,
                    Buffalo Board and/or Hexagrip?
                    Rod
                    #527200
                    ega
                      @ega
                      I know it simply as "phenolic-faced ply" but I suppose there may be a brand name.
                      AFAIK, Formica is a thin laminate ie not a board material as such.
                      #527207
                      Peter Cook 6
                        @petercook6
                        Thin stainless sheet glued down on a piece of MDF. Thin stainless is available as cooker splashbacks or just as sheet.
                        #527209
                        noel shelley
                          @noelshelley55608
                          If stainless will do PM me. Noel
                          #527215
                          Hollowpoint
                            @hollowpoint
                            Thanks for the replies.
                            I have some stainless sheet (thanks anyway Noel) and have considered gluing a piece to some ply and I might yet go down that route.
                            My requirements though are quite specific. I have built a base from aluminium extrusion to house the motor and electrics for a small Cowells lathe, The board will sit in the top and be screwed up from the bottom. I want something durable and scratch resistant, I could use wood but I feel it will start to look tatty relatively quickly. Metal would be better, but will scratch. Hard plastic seems like a good compromise as it will do what I want while also having the benefit of insulating the electronics below.
                            #527224
                            Grindstone Cowboy
                              @grindstonecowboy
                              Corian would be good if you could get an offcut from a kitchen/bathroom fitter.
                              Rob
                              #527228
                              Hollowpoint
                                @hollowpoint
                                Posted by Grindstone Cowboy on 14/02/2021 16:51:59:
                                Rob
                                Yes that might be an option. Thanks
                                Has anyone used SRBP? it seems to be quite cheap and plentiful on ebay.
                                Edited By Hollowpoint on 14/02/2021 17:06:02
                                #527236
                                  Posted by Hollowpoint on 14/02/2021 17:01:12:
                                  But isn’t that typically Brown in colour ?
                                  … as per the Tufnol products that you rejected
                                  Hollowpoint
                                    @hollowpoint
                                    It seems to be available in black too. smiley
                                    #527239
                                      Posted by Hollowpoint on 14/02/2021 17:13:23:
                                      Then use it, and be happy yes
                                      Edit: __ Possibly this : https://www.attwater.com/products/b4b
                                      Edited By Michael Gilligan on 14/02/2021 17:21:51
                                      #527253
                                      Martin Dilly 2
                                        @martindilly2
                                        Hollow, I have an unused 6 ft length of white Formica kitchen work surface which you, or anyone else, are welcome to, f.o.c. I'm in the Bromley/Croydon area if that's any help.
                                        #527261
                                        larry phelan 1
                                          @larryphelan1
                                          I hate a workbench that has scratches on it ! Dont you ?cheeky
                                          #527266
                                          Hollowpoint
                                            @hollowpoint
                                            Posted by Martin Dilly 2 on 14/02/2021 17:43:28:
                                            Thank you for the offer, very kind! but I'm in the Leeds area so a fair distance away and I've just ordered a piece of SRBP so will give that a go. yes
                                            #527269
                                            Hollowpoint
                                              @hollowpoint
                                              Posted by larry phelan 1 on 14/02/2021 17:59:57:
                                              It's more of a box to be fair, haha. laughcheeky
                                              #527282
                                              Nick Wheeler
                                                @nickwheeler
                                                Several colours of overspray smudged around with brake fluid and thinners soon takes care of that….
                                                #527611
                                                David Senior
                                                  @davidsenior29320
                                                  Trespa offcuts are available from David Meddings DeSign (or they used to be when he had the unit next door to my work – he has now moved further up the industrial estate so I don't see the piles of material any more). I don't have a contact number handy but I am sure you can find him on Google – he also used to trade as Reel Furniture. He is in Attleborough, Norfolk
