Posted by SillyOldDuffer on 06/02/2021 14:53:19:
- Switching off and on again. Restarting the machine causes it to clean everything up. Sometimes this is the only way to fix a malfunction that failed to release memory after use.
If it's Windows-8 or 10 and you have Fast-Startup enabled (the default) you need to be careful:
Doing a <Shutdown> results in Windows saving the kernel to disk and reloading it when you start up again. In this case you have no guarantee the memory is cleared.
Doing a <Restart> doesn't turn the machine off but does reload Windows from scratch and will clear the memory.
(IMO these procedures are counter-intuitive … thanks MS)
Holding down the SHIFT key while doing a <Shutdown> will bypass saving the kernel, shut down the machine and reload Windows from scratch at next boot.
